Trying to follow the “Particle fun” tutorial I used the Classic shader for particles as replacement of the Mantra Surface.
The rendering result is odd, with no points and instead some big spheres.
Confused if I need to use a different shader - using Principled Shader didn't change anything - or something else.
Render particles problem
11092 6 1- davide445
- 54 posts
- Enivob
- 2537 posts
On the actual top level node there is a Render tab. Inside that tab there is Geometry tab. Inside that tab set it to not render unconnected points as spheres. By default Mantra assumes you want to see unconnected points as spheres.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- 7771 posts
- davide445
- 54 posts
Using your suggestions I did find indeed source_particles>Render>Geometry>Render As Points property.
Setting as No Point Rendering didn't produce any output. Setting as Render Only Points you can change the point size using the Point Scale and achieve nice results.
Edited by davide445 - June 16, 2017 03:28:32
AMD Ryzen 5 2600X, 4x16GB 3200 Mhz, Kfa2 GTX 1070 EX 8GB, Windows 10 Pro, KDE Neon
- naren srinivasan
- lewis_T
- 238 posts
Please don't ever adjust the point scale on this level, as far as I'm concerned it should be removed
from Houdini altogether. Do it inside SOPs with a wrangle. Setting it at this level means if you
export these particles, they WILL NOT inherit the value you set at OBJ level. It is shit.
- 8555 posts
tinyhawkusIt's there to be able to adjust the scale even if your particle cache is loaded as packed disk without the need to write it all to ifd or recache again
so it has its uses
