how can one produce a hex grid in houdini ?
26249 20 7- pheryel
- 11 posts
- mestela
- 1737 posts
- anon_user_37409885
- 4189 posts
- Konstantin Magnus
- 670 posts
A rough implementation of a hexgrid algorithm would be connecting two attribwrangles: Set the first one to detail and the second one to run over points.
If you want to dig a tiny little deeper, here is the source:
http://www.redblobgames.com/grids/hexagons/ [redblobgames.com]
http://www.redblobgames.com/grids/hexagons/implementation.html [redblobgames.com]
// Creates a point grid in detail mode for(int j = 0; j < 10; j++){ float shift_x = ( (j + 1) % 2 ) * 0.5; float shift_z = j * 0.75; for(int i = 0; i < 10; i++) { vector pos = set(i + shift_x, 0, shift_z); addpoint(0, pos); } }
// Draws hexagonal polygons on the grid int prim = addprim(0, "poly"); float height = (sqrt(3)/2) * 0.5; float width = 0.5; for(int i = 0; i < 6; i++) { float angle_deg = 60 * i + 30; float angle_rad = $PI / 180 * angle_deg; vector pos = set(@P.x + width * cos(angle_rad), 0, @P.z + height * sin(angle_rad) ); int pt = addpoint(0, pos); addvertex(0, prim, pt); }
- pheryel
- 11 posts
- RyuKu
- 171 posts
Hey!
Thanks for the examples shown.
@mestela
How you understood that we need to put 0.6 in second transform's x Scale to make polygons symmetrical? Is there a kind of logic in it or you've found that it works by tweaking scale?
@Konstantin Magnus
You have four nodes for this (grid + attribute wrangle + attribute wrangle + null)? I have source grid visible after hexagons are created, you've added some anoter node to delete it, or I did a mistake in code retyping and something there delete grid? Yours hexagons look the same sized on the image uploaded, but how do you know that they are? Is there something in written shows you that it is so? Using what in code you adjust spacing between hexagons?
Thanks for possible replies and advices
@mestela
@Konstantin Magnus
Edited by RyuKu - Nov. 22, 2017 06:06:35
- mestela
- 1737 posts
- RyuKu
- 171 posts
- Konstantin Magnus
- 670 posts
Hi Ryu,
No, just two wrangles (see attachment).
Multiply the same value on height and width.
Ryu Ku
Ryu Ku
- RyuKu
- 171 posts
- vusta
- 555 posts
so here's my way…it boils down to divide and conquer…or translated to: create a unit of something, clone it, offset it, radial clone it…whatever….it's just cloning…
I'm not a coder so cannot cram things into one wrangle…but for other non-programming ppl out there..you can look at my files here:
https://www.facebook.com/groups/HoudiniArtists/permalink/1467625033353296/ [www.facebook.com]
step-by-step are pretty easy to understand…it's just cloning, offsetting…
(oh yes…mine produces points…so technically not a grid)
Edited by vusta - Nov. 24, 2017 02:37:16
- RyuKu
- 171 posts
- anon_user_89151269
- 1755 posts
- vusta
- 555 posts
- RyuKu
- 171 posts
@vusta
Very interesting approach to create hexagon, you've reminded me that I need to find out how to work with For-Each Loops still don't know it Changed you packing tube to six Columns, like the effect it gives and like how you've called the file, didn't think about miel before it relatively to hexagons Thanks for the example
Edited by RyuKu - Nov. 24, 2017 13:20:51
- Schmauch
- 21 posts
I tried to replicate the code of Konstantin Magnus and the hex was always squished a bit. What gave me an regular hex was this. Took me some time to figure out because I don´t know my way around math very well. Perhaps it can be of help to someone.
@Konstantin Magnus Thanks for the starting point and the wonderful Red Blob Games [www.redblobgames.com] link
int prim = addprim(0, "poly"); float size = 0.5; for(int i = 0; i < 6; i++) { float angle_deg = 60 * i-30; float angle_rad = $PI / 180 * angle_deg; vector pos = set(@P.x + size * cos(angle_rad), 0, @P.z + size * sin(angle_rad) ); int pt = addpoint(0, pos); addvertex(0, prim, pt); }
- BabaJ
- 2038 posts
Saw this post a while back and wanted to give it a whirl but didn't have the time…had time today.
I seperated the hexagons into two vex nodes - one for just creating the hexagons points (their hex “corners”).
And the second to make them into polylines or polygons.
The third node is an add node just to quickly create the polygons by attribute ( in this case the hex number ).
Both vex nodes have a folder tab with control paramters.
The first vex node name “Create Hexagon Points” has the following controls:
* Hexagon starting point
* Hexagon Radius
* Number of Hexagons per row
* Number of Rows
The second vex node has the parameter to switch back between polys or polylines.
* Hexagon Radius
* Number of Rows
Edited by BabaJ - May 4, 2018 21:37:47
- Konstantin Magnus
- 670 posts
A non-mathematical approach would be
- a grid with alternating triangles,
- grouping its crossing points,
- scaling it by ~1.7 along X,
- and copying six sided circles on them.
- A fuse will cover tiny imprecisions.
- Nick Wood
- STEVLTH
Thanks to everyone for your methods. I made my own super simple method, that converts the default grid to hexagonal grid using ‘pointsfromvolume’ node with Tetrahedral point configuration.
You can easily control grid size, hexagon size (Point separation in the ‘pointsfromvolume’ and hexagon offset (circle radius).
