point vop ramp doesn't output colors
5661 6 0- olivierth
- 1012 posts
- mestela
- 1747 posts
I thought you might have to cast ptnum to a float, but works fine here.
Attached a hip if you want to compare against your setup.
For the record, that method won't work so well if you have multiple curves. A more reliable method is to generate uvs, either with a uvtextures op in ‘rows and columns’ mode, or a resample sop with everything turned off, apart from ‘curve u attribute’.
They're in the hip too.
-matt
-matt
- olivierth
- 1012 posts
Hi mestela!
Thanks for the detailed example! As a noob, I really appreciate it!
I'm a little confused. On the example where you tried my approach, your ramp contains a gradient from black to white and the viewport result is green to red….?! I also copied your ramp into my scene to replace mine and it's still black…
The multiple curve thing is good to keep in mind!
- olivierth
- 1012 posts
- sepu
- 433 posts
- olivierth
- 1012 posts
- 8613 posts
