Supercharged H20 extension (TouchDesigner Style)
27822 92 8- raumafu
- 30 posts
- animatrix_
- 4523 posts
utility_hotkey_system.py
- raumafu
- 30 posts
- animatrix_
- 4523 posts
omerlefaruk
Is there a way to create custom hotkey.csv files for different desktops? Or maybe assign a hotkey to change hotkeys? I wanna be able to change my custom hotkeys to grooming tools when i do grooming and terrain tools when i do terrain. Is it possible to do this?
Yes you can do this easily, you just have to create different CSV files and implement the logic to load different ones based on some mode that you can store for example.
Check utility_hotkey_system.py
def __load_actions(): if showstatus: print ("Reloading hotkeys...") global __actions __actions = defaultdict(lambda: defaultdict(list)) with open(hotkeysfile) as f: reader = csv.DictReader(f) for row in reader: for context in ("OBJECT", "SOP", "VOP", "DOP", "COP2", "CHOP", "SHOP", "DRIVER", "TOP", "LOP"): if row[context] != '': __actions[context][row["Key Name"]].append(row[context]) __load_actions() this.fs_watcher = QtCore.QFileSystemWatcher() this.fs_watcher.addPath(hotkeysfile) this.fs_watcher.fileChanged.connect(__load_actions) showstatus = True
- raumafu
- 30 posts
- animatrix_
- 4523 posts
Perhaps OdTools also override the nodegraph hooks? That would be my guess.
- raumafu
- 30 posts
Is it possible to use overlay menu in network view list in lists? I wanna create a list that includes then create heightfield noises list with in the heightfield menu that i just created.
I'm trying something like this but no luck
mn:[('op:heightfield', 'H')]
mn:[('op:heightfield_noise', 'N')]
mn:[('Heightfield', 'op:heightfield', 'H'), ('mn:[('Heightfield_Noises', 'op:heightfield_noise', 'A')]', 'N'), ('op:heightfield_blur', 'B')]
Edited by raumafu - Sept. 7, 2022 17:45:24
- oliver7
- 282 posts
animatrix_yeah.. sorry.. it does...
Oliver Hotz
Origami Digital
Author of ODTools for Houdini: https://origamidigital.com/cart/index.php?route=product/product&path=59_63&product_id=66 [origamidigital.com]
Origami Digital
- kylehamm
Hey there, I've been really enjoying the addon so far.
Just one question I haven't been able to figure out yet. In the Advanced UI Customization video you mention the ability to use shortcuts to toggle open/close some of the other panes, like the geo spreadsheet. Are there default shortcuts you have created to do that or do I need to set them up myself?
Also, is it possible to set the network view overlay to toggle off/on without having to hold down the spacebar to see the 3D viewport? For example, press spacebar once to turn off the network view overlay and show the 3D view, and then another spacebar press to bring it back?
- animatrix_
- 4523 posts
raumafu
Is it possible to use overlay menu in network view list in lists? I wanna create a list that includesthen create heightfield noises list withmn:[('op:heightfield', 'H')]in the heightfield menu that i just created.mn:[('op:heightfield_noise', 'N')]
I'm trying something like this but no luckmn:[('Heightfield', 'op:heightfield', 'H'), ('mn:[('Heightfield_Noises', 'op:heightfield_noise', 'A')]', 'N'), ('op:heightfield_blur', 'B')]
You mean different configurations of the same node? If so yes, you can invoke presets from anywhere include the menus.
My latest H key is like this where Group Highlight is AttribWrangle preset.
H,,"mn:[('op:groupcombine', 'C'), ('op:groupcopy', 'Y'), ('op:groupdelete', 'D'), ('op:groupexpand', 'E'), ('op:groupexpression', 'X'), ('op:groupfindpath', 'F'), ('op:groupfromattribboundary', 'B'), ('op:attribwrangle(Highlight Group)|Group Highlight', 'L'), ('op:grouppromote', 'P'), ('op:grouprange', 'A'), ('op:grouprename', 'R')]","mn:[('op:bbox', 'B'), ('op:relbbox', 'R'), ('op:primuv', 'P'), ('op:primnormal', 'N'), ('op:intersect', 'I'), ('op:intersectall', 'A'), ('op:minpos', 'M'), ('op:xyzdist', 'X'), ('op:displacenml', 'D'), ('op:surfacedist', 'S'), ('op:ingroup', 'G'), ('op:texture', 'T')]",,,,,,,
kylehamm
These hotkeys I configured using Supercharged shelf buttons that was created. So you can assign your own hotkeys if you are not using my overrides, where some of the tools are:
<memberTool name="toggleOverlayNetworkEditor"/> <memberTool name="toggleNetworkEditor"/> <memberTool name="toggleDetailsView"/> <memberTool name="togglePerfMon"/> <memberTool name="toggleParameterEditor"/> <memberTool name="toggleSceneView"/> <memberTool name="toggleSceneRenderView"/>
The default key for toggling the overlay network editor is ` (tilde) key but you can assign Space too. Because Space key is a special volatile key. So if you want to do this, open up the HOUDINI_USER_DIR/animatrix/overlay network editor/python3.9libs/pythonrc.py and change this line:
useVolatileSpaceToToggleNetworkEditor = True
to:
useVolatileSpaceToToggleNetworkEditor = False
Hope you enjoy it!
- raumafu
- 30 posts
Both actually. I want to assign a hotkey for opening a menu like this
-- Press the menu hotkey H --
--Heightfield_Nodes, H
--Heightfield_Presets, P
--Heightfield_Noise Presets, N
-- Pressed P --
I--Heightfield_Noise_Default, H
I--Heightfield_Noise_Low_Freq_Preset, P
I--Heightfield_Noise_High_Freq_Preset, V
A menu that opens another menu that opens another menu with custom node presets.
Image example attached.
-- Pressed P --
Edited by raumafu - Dec. 11, 2022 11:32:28
- animatrix_
- 4523 posts
I see what you mean. By default the built-in menu system only supports one level. It would likely need to be extended further to support multi-level menus. You can edit the performAction and executeActionString functions inside utility_hotkey_system.py for this.
- raumafu
- 30 posts
- animatrix_
- 4523 posts
raumafu
Is it possible to add ALT key as a volatile key for viewport instead of space key for overlay network view?
You can use the setVolatileKeys(keys) function:
https://www.sidefx.com/docs/houdini/hom/hou/NetworkEditor.html [www.sidefx.com]
I have a feeling just the modifier key by itself might not work but it's worth a try.
- raumafu
- 30 posts
I have found this function inside utility.ui and i'd like to use this function with a hotkey inside a wrangle but when i assign a hotkey to this function inside a hotkey editor, it just doesn't work. How can i use this? My workaround is that i click an empty space in the parameter window, press the hotkey then ctrl + v paste the number inside a wrangle. Is this the correct behavior?
def pasteRandomNumber(digits=4, decimals=4): rnd = np.random.uniform(0, pow(10, digits), 1)[0].round(decimals=decimals) hou.ui.copyTextToClipboard(str(rnd)) key = QtGui.QKeyEvent(QtGui.QKeyEvent.KeyPress, QtGui.Qt.Key_V, QtGui.Qt.ControlModifier, "V") QtWidgets.QApplication.sendEvent(QtWidgets.QApplication.focusWidget(), key)
Edited by raumafu - Aug. 22, 2023 14:50:44
- animatrix_
- 4523 posts
raumafu
I have found this function inside utility.ui and i'd like to use this function with a hotkey inside a wrangle but when i assign a hotkey to this function inside a hotkey editor, it just doesn't work. How can i use this? My workaround is that i click an empty space in the parameter window, press the hotkey then ctrl + v paste the number inside a wrangle. Is this the correct behavior?def pasteRandomNumber(digits=4, decimals=4): rnd = np.random.uniform(0, pow(10, digits), 1)[0].round(decimals=decimals) hou.ui.copyTextToClipboard(str(rnd)) key = QtGui.QKeyEvent(QtGui.QKeyEvent.KeyPress, QtGui.Qt.Key_V, QtGui.Qt.ControlModifier, "V") QtWidgets.QApplication.sendEvent(QtWidgets.QApplication.focusWidget(), key)
Normally it should just work that. Basically the code generates a random number, copies it into the clipboard and then invokes Ctrl+V. So it should paste this number wherever the caret is currently.
- animatrix_
- 4523 posts
Supercharged extension is updated to be fully compatible with Houdini 20. It also implements the latest changes to be more in line with the latest API, such as the new hotkey standard to use unmodified keys:
https://www.sidefx.com/docs/houdini/news/20/hotkeys.html [www.sidefx.com]
The new version is freely available to existing users. Enjoy
- a2jixrxau
I have a problem using Houdini 20.0
When I right-click, it looks like this
File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.506/houdini/python3.10libs\nodegraph.py", line 170, in handleEventCoroutine
event_handler = event_handler.handleEvent(uievent,
File "C:\Users/User/Documents/houdini20.0/animatrix/hotkey system/python3.10libs\nodegraphhooks.py", line 229, in handleEvent
uievent.editor.openTabMenu(key = utils.getDefaultTabMenuKey())
TypeError: getDefaultTabMenuKey() missing 1 required positional argument: 'editor'
- animatrix_
- 4523 posts
a2jixrxau
Hi, that's strange. I am unable to reproduce it. Which context and how are you right clicking i.e. is it on a node, etc? Recording a video would help.
- raumafu
- 30 posts
animatrix_
Is it also updated on the patreon?
