Custom HDAs Not Supported in LOPS?
6140 31 2- jlapre
- 133 posts
in our planetarium production pipeline, we have a number of HDAs we developed. They work in our /obj context using Mantra.
For e.g. we have a globe (planet) HDA that uses DEM and satellite visual data.
We want to be able to add LOPS/Karma to our Houdini workflow.
However, when I try to Scene Import (All) our custom HDAs from /obj into /stage, we get the warning: Skipped Object "..." because its type isn't supported.
I have attached a simplified example.
In my example, I created a geo node in /obj with a torus sop. Then converted this into a simple HDA called my_torus.
When I create a Scene Import (All) LOP, I get the above warning.
As a workaround, I try to import my HDA using an SOP Import LOP. Which works, but then it loses the transform inherited by the null hierarchy in the source /obj context.
What am I missing?
What am I missing?
Edited by jlapre - May 20, 2022 15:12:47
Jeroen
- 8622 posts
For custom object types you may have to create your own translator plugin
https://www.sidefx.com/docs/houdini/hom/sceneimport_object_translator.html [www.sidefx.com]
Edited by tamte - May 20, 2022 15:16:32
- 7845 posts
- jlapre
- 133 posts
- 7845 posts
jlapre
Thanks jsmack.
I'm having trouble finding documentation or an example of how to add object processor scripts.
Could you point me to documentation or an example of registering the existing translators under the hda names?
Thanks again.
The article Tomas posted is the only documentation I know of, but you can open the base.py object translator in the Houdini directory for example code.
- jlapre
- 133 posts
- robp_sidefx
- 455 posts
- jlapre
- 133 posts
Hi Rob. No worries. I understand that with great power comes great responsibilities.
What would be helpful is if you took my simplified my_torus HDA and provided a specific python example.
As Pixar’s USD Python APIs are a steep learning curve.
https://graphics.pixar.com/usd/release/api/index.html [graphics.pixar.com]
It would also be helpful if your Houdini 19.0 Python scripting documentation:
...had a link to the above and these tutorials.
https://graphics.pixar.com/usd/release/tut_usd_tutorials.html [graphics.pixar.com]
Edited by jlapre - May 21, 2022 12:29:50
Jeroen
- jlapre
- 133 posts
robp_sidefx
If there's anything in that documentation link that you find confusing/missing, please let us know!
I appreciate that we've simultaneously increased both the flexibility and the cost of dealing with custom object types via SceneImport in Houdini 19.0.
What would also be helpful is if the warning in the Scene Import LOP included "if you want your HDA to import into LOPS then you need to implement a Scene Import LOP object translator plugin". With a link to:
The warning gave me the false impression that custom HDAs are not supported by LOPS. Hence the name of this thread.
Edited by jlapre - May 21, 2022 12:59:57
Jeroen
- 7845 posts
Hey Rob, thanks for replying. I'm trying to follow along and figure out the object translators as well. At the end each module, they define a registerTranslators function and call registerTranslator with what looks like a node type name as the first argument. This seems straightforward. In base.py, I see a translator registered for 'xform', but there is no such object node type. What is this for?
- robp_sidefx
- 455 posts
jlapre
Here's the simplest translator:
import husd class TorusTranslator(husd.objtranslator.Translator): def shouldTranslateNode(self): return True def primType(self): return 'Xform' def registerTranslators(manager): manager.registerTranslator('my_torus', TorusTranslator)
You can rapidly increase the complexity if you want to start handling custom attributes, visibility, etc. Specifically regarding visibility, it's on my todo list to add an additional translator base class (something like husd.objtranslator.VisibleTranslator) so that the logic for handling the obj-level visibility flag can be more centralised.
Yes, that's an excellent suggestion. RFE made!
- robp_sidefx
- 455 posts
jsmack
That's an excellent question, and the short (and embarrassing) answer is: it serves no point whatsoever. At one point in the development history I was using the XformTranslator as an internal base class, but then I undid that and I think I just blindly registered it as its own translator even though, as you rightly note, there is no xform Object node.
- jlapre
- 133 posts
robp_sidefxjlapre
Here's the simplest translator:import husd class TorusTranslator(husd.objtranslator.Translator): def shouldTranslateNode(self): return True def primType(self): return 'Xform' def registerTranslators(manager): manager.registerTranslator('my_torus', TorusTranslator)
You can rapidly increase the complexity if you want to start handling custom attributes, visibility, etc. Specifically regarding visibility, it's on my todo list to add an additional translator base class (something like husd.objtranslator.VisibleTranslator) so that the logic for handling the obj-level visibility flag can be more centralised.What would also be helpful is if the warning in the Scene Import LOP included "if you want your HDA to import into LOPS then you need to implement a Scene Import LOP object translator plugin".
Hi Rob,
thanks for the simplest implementation example. I'll give that a try.
Also thanks for adding my suggestion to the warning details.
Jeroen
- jlapre
- 133 posts
Hi Rob,
I created a file called my_torus.py with the bare-bones code you provided.
See attached.
I'm currently testing on macOS BigSur, so I put this file here:
That worked!
Thanks again.
See attached.
/Applications/Houdini/Houdini19.0.561/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/husdplugins/objtranslators/
That worked!
Thanks again.
Jeroen
- jlapre
- 133 posts
jlapre
Hi Rob,
See attached.
I'm currently testing on macOS BigSur, so I put this file here:/Applications/Houdini/Houdini19.0.561/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/husdplugins/objtranslators/
That worked!
Thanks again.
One caveat is that if I version up using the new Houdini 19 version up minor version mechanism, then the Scene Import LOP breaks again.
I tried duplicating my_torus.py to
my_torus.1.0.py
my_torus__1.0.py
my_torus__1_0.py
But non of the above worked.
Do I need to register each version in the python file itself?
e.g.
manager.registerTranslator('my_torus::1.0', TorusTranslator)
Jeroen
- jlapre
- 133 posts
- robp_sidefx
- 455 posts
- 7845 posts
robp_sidefx
As you've found, you can share a single translator across many different node-types, just adding new registerTranslator() calls for each.
Where/when do register translator calls have to happen? Can they happen in the 456.py? Especially how to deal with Studio HDA libraries that are installed from a DB using 456 hooks.
- jlapre
- 133 posts
robp_sidefxjlapre
I answered my own question.
My favourite kind
Yes, SceneImport is very strict about naming (versions, namespaces, etc) ... for better or worse.
Hi Rob,
I tried to increment my_torus::1.0 again to my_torus::1.1, and updated my_torus.py accordingly.
my_torus::1.1 works, but when I switch back to my_torus::1.0, it breaks in LOPS again.
Even if I save, quit out of Houdini, then re-launch.
It now only appears to recognize the newest version of the HDA.
What am I missing?
Jeroen
- robp_sidefx
- 455 posts
Ah, sorry for any confusion. Where you currently have:
You should have:
def registerTranslators(manager): manager.registerTranslator('my_torus', TorusTranslator) def registerTranslators(manager): manager.registerTranslator('my_torus::1.0', TorusTranslator) def registerTranslators(manager): manager.registerTranslator('my_torus::1.1', TorusTranslator)
You should have:
def registerTranslators(manager): manager.registerTranslator('my_torus', TorusTranslator) manager.registerTranslator('my_torus::1.0', TorusTranslator) manager.registerTranslator('my_torus::1.1', TorusTranslator)
