Hi
I recently started using the Karma renderer, is it possible to render Particle Sprite with the Karma renderer?
I tried rendering a Particle set up in Sprite SOP with Karma, but the Sprite was not rendered...
If you know of any documentation, etc., I would appreciate it if you could let me know.
Particle Sprite with Karma?
3649 8 3- Uryu
- 34 posts
- maks dannikov
- 9 posts
Hi Uryu,
you can use "Render Geomtry Settings" LOP and switch between different render options for points. Parameter calls "Render Points As". Points can be rendered as camera oriented discs, spheres or discs oriented to the normal attribute.
However, I don't think disks have any UV or "st" coordinates what can be useful for shading... I've tried to access with materialx and vex shaders but both with no luck. Is there any ways how I can access it?
- 7809 posts
- 8597 posts
looks like a big oversight, particles should definitely have a sprite rendering mode
you can't fake it with lookat constraint, not only it is tedious workaround
it also doesnt behave like sprites
the main advantage of sprites (at least to my understanding) is that they face all the rays that evaluate them (like for shadow cating etc...), unlike oriented rectangles
- 7809 posts
tamte
a renderer would have to support sprites though, and I think modern renderers are essentially triangle tracers now, so geometry that looks different from different angles won't work.
Sure, there could be a spriteAPI at the USD level to make it more portable or easy to author, but it's probably not something Pixar needs.
- 8597 posts
jsmackwhat about rendering curves as ribbons? isn't that the same principle?
Karma supports those, so why wouldn't sprites
EDIT: or even rendering particles as discs should be rendered based on ray direction, are you saying it's not the case with Karma?
EDIT2: just checked, it renders discs properly based on ray direction, so no excuse for not having proper sprite type
Edited by tamte - Aug. 3, 2022 22:25:39
- Uryu
- 34 posts
- syntheticperson
- 159 posts
- jlapre
- 132 posts
Has anyone gotten the Sprites Procedural VOP node working in Karma?
https://www.sidefx.com/docs/houdini/nodes/vop/sprite.html [www.sidefx.com]
The documentation only mentioned Mantra, not Karma.
Jeroen
