Hey Houdniks,
This happend the other night when updated a obj file.
Basically the origin gnomon is offset or tilted. The object is aligned to it, but the Grid isnt.
Here is a nice pic of it.
What did i do wrong.
Origin Gnomon offset Error! or maybe not
8079 14 0- phrenzy84
- 249 posts
- jens_martensson
- 341 posts
- edward
- 7733 posts
- phrenzy84
- 249 posts
- JColdrick
- 4140 posts
- phrenzy84
- 249 posts
- goldfarb
- 3455 posts
- phrenzy84
- 249 posts
i thought that, but then i couldnt find any controls to offset the construction grid :p.
Plus renaming the HOME directory would reset all preference changes right?
also, as a side question what are the normal set of enviroment variables, i have the feeling ive deleted some. Ive only got the HOUDINI_MMB_PAN one, shouldnt i have a few more, like HOUDINI_PATH etc?
thanks again guys.
btw i think the problem to this is when i import a file of a particular scale.
thanks again guys.
- edward
- 7733 posts
- phrenzy84
- 249 posts
- edward
- 7733 posts
- phrenzy84
- 249 posts
- phrenzy84
- 249 posts
There you go boys and girls.
Still dont know what threw it off in the first place, also if the origin gnomon is small, switch to a left or any other ortho view and switch back to perspective and it should be reset also.
Case closed
edit/ not quite, for some reason it gets locked to an object that has rotation so it gets knocked out of wack again, so you need to keep reseting the grid. So for now ive turned it off, but this has to be a bug of some kind, i cant find a way of unlocking the grid to the object. Thanks for the help everyone.
Case closed
- edward
- 7733 posts
- phrenzy84
- 249 posts
