Hi guys, just got a copy of houdini and keep getting this error message when i try to either import a geometry or use mantra, the message is the same on both. the message reads as follows
any advice?
Error when trying to import and use mantra etc
4962 10 1- RCoomber
- 5 posts
- JColdrick
- 4140 posts
- RCoomber
- 5 posts
- JColdrick
- 4140 posts
Vista? Then I'd still say at least look at permission issues. You running vista with UAC turned off? If you flip it on and off, lots of strange things can happen because of the virtual file system UAC uses.
Try downloading another more recent release - usually there are daily releases, if you reused the same installer, perhaps there's a problem with the file(posts at sesi are all good as long as not marked red, but it's possible you have something interfering with your downloads). Don't use any ‘helpers’ or anything that might interfere with the download.
There has to be something unique about your setup since obviously lots of people are running it on windows without troubles. At this point that's all I can think of, perhaps someone else can chime in if they have a notion.
J.C.
J.C.
John Coldrick
- RCoomber
- 5 posts
- goldfarb
- 3455 posts
- RCoomber
- 5 posts
- JColdrick
- 4140 posts
- edward
- 7725 posts
It definitely looks like a space issue in the path. The problem though is that there shouldn't any space issues in the path. I've been installing Houdini into the c:\Program Files\etc… for the longest of times and haven't run into the problems that some people have. I suspect that their Windows installation deviates from the ones I've used in some weird way. (and I've used Houdini on everything from Windows NT 4, 2000, XP, Vista). Which version (ie. 9.X.XXX) of Houdini are you running?
- RCoomber
- 5 posts
- edward
- 7725 posts
