Does anybody have experience moving FormZ models to SideFX Houdini?
There are quite a few image file formats that the two applications have in common. Unfortunately none of them work successfully for me with I thought was a pretty simple object. In general, I can import that geometry in to Houdini, but then I get an message saying there was an error loading geometry.
I think I am doing thing correctly as I have been able to import 3D geometry from other sources.
I have also posted on the FormZ forum, but I figure I would also check here to see if anybody has luck doing this.
Windows 7 x64
FormZ 8.00
Houdini 14.291
FormZ
3289 8 1- Reynold Dodson
- 28 posts
- goldfarb
- 3455 posts
- Reynold Dodson
- 28 posts
- Reynold Dodson
- 28 posts
- Reynold Dodson
- 28 posts
OK, I have done some more testing, now it appears as though my current installation of Houdini Indie does not important ANY geometry.
Attached is a file that opened up in Houdini 13, but does not open in 14.0.258. Can any else open this file?
I checked the specs on Indie and it does not appear as though anything has changes with regards to read geometry files.
Thanks for any ideas…
Here is my system:
latform: windows-x86_64-cl17
Operating System: Windows 7 Professional Service Pack 1 x64 (6.1.7601)
Number of Cores: 40
Physical Memory: 63.97 GB
Number of Screens: 2
Screen 0: 1920 x 1200 at 0,0
Work Area 0: 1920 x 1170 at 0,30
Screen 1: 1920 x 1080 at 156,1200
Work Area 1: 1920 x 1080 at 156,1200
OpenGL Vendor: NVIDIA Corporation
OpenGL Renderer: Quadro K5000/PCIe/SSE2
OpenGL Version: 4.4.0
OpenGL Shading Language: 4.40 NVIDIA via Cg compiler
Detected: NVidia Professional
4096 MB
334.95.0.0
Here is my system:
Number of Cores: 40
4096 MB
334.95.0.0
- Reynold Dodson
- 28 posts
A little more information about this error.
I call File > Import > Geometry
Select the *.obj file (in this case)
A new node is created
I click into this node and the file object shows the red error stripes. In the properties the message is “Unable to read file Gear10Teeth.obj”.
The behavior is the same for any file type that I try to open.
- Enivob
- 2537 posts
I saw the same message but Houdini does indeed load the .OBJ file.
With your node selected move your mouse into the 3D viewport, hold down the spacebar and press the G-KEY. Your gear is huge. SPACEBAR-G will zoom you out to a view that will frame your object.
Edited by - May 18, 2015 12:52:04
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- Reynold Dodson
- 28 posts
- sl0throp
- 258 posts
