How to output the UV channel created by the UV triplanar node? and few other important questions for the magicians....
   5333   8   1
- Hey guys, looking for this, is there a way?
Thanks,
-Is there a way to archive a scene with all these dependency, textures and models input….?
vincent*
________________________________________________________________
Vincent Thomas
Lead LookDev Lighting / Senior Matte Painter & Creative Since 1998
http://fr.linkedin.com/in/vincentthomas [fr.linkedin.com]
Vincent Thomas   (VFX and Art since 1998)
Senior Env and Lighting  artist & Houdini generalist & Creative Concepts
There is no way to make a single uv map from a triplanar texture. A triplanar texture is 3 (or 6) planar mappings blended by the surface normal. The uv space is, in a sense, just euclidean space.
As it etablish a relation between each vertex in space and a corresponding 2d pixel, i thought this was enough to obtain a UV layout as splitted it might looks… I guess im wrong in my understanding what uv map really means mathematically…
vince*
it's just that triplanar projection is not creating one texture space which you can use to map an image to
it creates 3 spaces then applies 3-6 textures to and blends them based on facing ratio between those axes and supplied normals
so if you want to bake that, you'd have to create 3 uv maps and 3-6 masks for your textures, which you can do if you want by directly outputting relevant data from triplanar projection node to some attributes
Edited by tamte - March 29, 2017 18:57:17
thanks make sence…
Is there any way toarchive a hip file with all these dependencin?
Is there also any spreadhsheet available concerning images being used?
Do you guys know?
I think to answer that we need to know what you want to export to.
Is it a game engine or specific file format?
Kai Stavginski
Senior Technical Director
Nothing specfic, just want to pack an houdini archive of my scene with no more outside references… See what i mean?
Hi there.
you could bake new textures. Would require UV coordinates on the objects.
Have Fun
Olaf
Anyone ? than how to have a list of all images with path being used in the current loaded scene?
cheers
