Not sure how to do this but I need to randomly choose between multiple source objects in a copyTo point SOP.
Imagine a Sphere with Scattered points on the surface.
Now using a copyTo SOp imagine having to copy not just 1 object to these points, but randomly choose between multiple.
ie For 3 objects instead of copying just a green colored grid, randomly choose either a red, green or blur grid for the copyTo points (on the sphere) operation.
Randomly choose between mutliple source objects for copy To operation
7688 3 1- art3mis
- 350 posts
- merlino3d
- 65 posts
hey Eco! If there's no specific reason you must use “copy to geometry”, I think you should use “copy stamp” instead.
Check this video:
https://www.sidefx.com/tutorials/copy-stamping-node/ [www.sidefx.com]
the idea is the same but you'll stamp the random value on a switch node in your left branch. The input for the switch node are all the objects you want to scatter.
I hope this can help
Check this video:
- art3mis
- 350 posts
- lemures
- 10 posts
Would suggest watching the new master class [sidefx.com].
But here's a quick example file for you. Just to note I use the spare input to get the detail. Just good practice with the new compile block added to 16.
