Boolean Fracture Alembic Export Workflow
1976 3 0- Midasssilver
- 310 posts
I have a simple boolean fracture sure, but when I export with an alembic rop, I get the mesh in Maya as a single object. Does anyone have an example file with proper Alembic export parameters? I will post a hip file myself when I get home in 2 hours. Any help would be appreciated. I've already spent over 6 hours trying to different export options.
- vusta
- 555 posts
- Midasssilver
- 310 posts
- jsmack
- 7767 posts
Use the path attribute to determine the exact shape and transform (group) nodes and hierarchy you desire. Ensure the Alembic ROP node has the option enabled to use the path attribute.
http://www.sidefx.com/docs/houdini/nodes/out/alembic.html#path-attribute [www.sidefx.com]
