Hello;
How could I set the “Playbar Loop mode” , to something like “Play Once”, as default value?
Thanks.
How could I set default value of playbar "Loop mode" to something else...?
2468 6 2- Masoud
- 407 posts
- HM_2020
- 43 posts
- anon_user_37409885
- 4189 posts
you can set the playbar mode with Hscript in a plain text file named 123.cmd file.
http://www.sidefx.com/docs/houdini/commands/play.html [www.sidefx.com]
You put this into a scripts folder, create if needed, inside the Houdini Preferences. i.e. on MacOS ~/Library/Preferences/houdini/16.5/scripts/123.cmd
play -1s
- HM_2020
- 43 posts
- Rebus B
- 80 posts
- HM_2020
- 43 posts
- toonafish
- 409 posts
Is this still the only way to adjust the default playback looping setting ? Very annoying when you forget to disable looping before running a simulation, so it starts again after it's finished.
One would expect there to be a setting in the preferences by now, but I still can't find it anywhere.
Thanks.
Thanks.
Edited by toonafish - Nov. 13, 2022 07:13:24
