Hi!
I'm following this tutorial:
https://www.sidefx.com/tutorials/rs4h-instancing-intermediate/ [www.sidefx.com]
But I'm stuck. When I set my s@instance of all points to the path of my sphere, it doesn't scatter like in the tutorial.
Can anyone have a quick look at my file?
Thanks.
-Olivier
instancing with wrangle (not getting the same thing as tutorial)
3697 8 1- olivierth
- 1007 posts
- toadstorm
- 359 posts
You can only instance object containers, not SOPs. So you could instance /obj/geo1, but not /obj/geo1/sphere1.
- raschberg
- 20 posts
- olivierth
- 1007 posts
- toadstorm
- 359 posts
yes.
to speed this up, if you create an object container called /obj/tree_oak_0001, you could drop down a file SOP that read those numbers in to determine which OBJ to load. for example:
$HIP/path/to/objs/tree_oak_`padzero(4, opdigits(“..”))`.obj
then just copy as many object containers as you need.
you could also try using s@instancefile instead of s@instance. then just set the attribute to be the full path of the geometry on disk that you want to instance. this may work more effectively with .bgeo than .obj.
- TwinSnakes007
- 604 posts
- olivierth
- 1007 posts
Hi toadstorm!
The s@instancefile sounds like the best/easiest way to work! I've tried it but it doesn't work. When I look at the spreadsheet, there is a space in the path… Is that normal?
Hi Daryl!
Thanks a lot for your tutorials! They are pushing me in the right direction.
Since you use Redshift, I was wondering if I could use the instance trick by browsing directly to Redshift proxies. Would that be a good idea?
-Olivier
Hi Daryl!
-Olivier
- toadstorm
- 359 posts
Your path is jacked up, probably because you're using backslashes instead of forward slashes. Backslashes are interpreted as escape characters, and “\t” is a tab, which is probably why you're getting that huge gap there. Just use forward slashes.
- olivierth
- 1007 posts
