I was trying to delete primitives based on normals, if they got too “vertical” by writing:
abs(@N.y)<0.1
into the group field of the Blast node.
Now this didn't work at all. not even as part of an If statement in a primitive wrangle SOP, the reason seeming to be, @N.y wouldn't get evaluated inside the parentheses. It started working, once I created a temporary float parameter from @N.y and used that in the if statement, but I'd like to understand, why this doesn't work and how this this limitation could be worked around in “on the fly” group creation of SOP nodes.
Thanks in advance.
Ivan
on the fly groups in SOPs
1140 3 1- ivanmalek
- 143 posts
- bonsak
- 459 posts
- tamte
- 8583 posts
this is all you can do in the group field, nothing too fancy
http://www.sidefx.com/docs/houdini/model/groups.html#manual [www.sidefx.com]
but your wrangle
but your wrangle
if(abs(@N.y)<0.1){}
should work out of the box without any temporary variables
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- mrCatfish
- 731 posts
