After the 20th time in the last month getting a call back from a client that the tiff files we sent “don't work” in Avid, is it possible to change the shipping default of Houdini tiff to LZW compression from the frustrating “Adobe Deflate”? I understand all the politics behind it, the idiotic file spec creep, all that - it just so happens that lzw or uncompressed tiffs are still pretty damned common out there, but you have to constantly remember to alter this everytime Houdini enters the mix. It doesn't fit with the “hurry, they're in a rush for it” pipeline. It's the only app that we use that has this problem.
Pretty please?
J.C.
Tiff Rage
3881 6 0- JColdrick
- 4140 posts
- edward
- 7732 posts
- JColdrick
- 4140 posts
OK, thanks Edward, but that wasn't really my point. I figured, being Houdini, it would be configurable, but don't you guys want your product to put out end results *by default* that work with other major apps in the biz? We've got this enabled shop-wide now, but all it takes is for a panic thing to happen that requires quickly sourcing a different job environment, send it out - doh!
J.C.
J.C.
John Coldrick
- jesta
- 311 posts
- wolfwood
- 4262 posts
jestaedward
Modify your $HH/FBoptions file and change the TIFF compression line to
TIFF compression LZW
But surely as soon as you upgrade Houdini you have to re-edit FBoptions, or can you place a copy in $HOME?
Anywhere in the Houdini path works. I think the file also supports #includes too.
- JColdrick
- 4140 posts
- JColdrick
- 4140 posts
