H18.0.287, Optix Denoser installed, Path entry is in the .env file and checked.
Whenever I switch to Karma the first time (no matter if Optix is enabled or not) I'm getting DSO errors for all the dlls in the Houdini dso/karma library. After that Karma renders fine.
Optix runs without issues in 17.5.
What am I missing? Is there anything else I need to configure?
Optix DSO error when switching to Karma
1638 6 0-
- OneBigTree
- 374 posts
- BabaJ
- 1898 posts
- jsmack
- 6423 posts
- OneBigTree
- 374 posts
- OneBigTree
- 374 posts
- jsmack
- 6423 posts
OneBigTreejsmackBut if it doesn't load properly suppressing the messages won't change that, would it? I usually have it a 2.
make sure you haven't set HOUDINI_DSO_ERROR > 0 in your env. Setting it to zero (default) will suppress the messages.
It loads properly. The messages are erroneous and can be ignored.
- mark
- 2497 posts
