VEX Arrays
   1551   3   0
Hello!
1) How can I create an array of arrays in VEX?
Example,
Iterate over primitives:
int an_array[];
int pts[] = primpoints(0, @primnum);
for(int i = 0; i < @numprim; ++i){
    push.(an_array, pts);
setdetailattrib(0, "an_array", an_array);
It should be like that in my understanding,
[[1,2,3], [4,6], [7,8,10,15]]
, but I get a single array with values.
[1,2,3,4,6,7,8,10,15]
2) How can I overload the Push function so that it can work with custom structures?
Example,
struct Test{
   int index;
   vector data;
Test test;
test.index = 1;
test.data = {1,0,0};
vector an_array[];
push(an_array, test);
But this code causes an error.
Edited by alexwheezy - March 10, 2020 10:26:02
Maybe it helps I use H 16.5, so what you want to achieve???
Post please your File
Structcolo.hipnc (75.6 KB)
1) Houdini doesn't support multidimensional arrays
https://www.sidefx.com/docs/houdini/vex/arrays.html [www.sidefx.com]
2) if this is a wrangle you need to define structs in outer code (./attribvop1/snippet1/Outer Code parameter)
and then this part:
vector an_array[];
should be changed to this
Test an_array[];
as you can only put float to float array, vector to vector array, Test to Test array, but not Test to vector array, etc…
FX Supervisor
Method Studios, NY
Thank you tamte for the quick reply and clarification. It is a pity, then will have to solve their problems in a different way.
