How to find normal of point neighbour
   1161   8   1
I want to use dot product to calculate points and neighbours points normal on same geometry,
try to make some effect like ambience occlusion.
I've use array and for loop to try to find them, but it {0,0,0}...
I know that I can use mask by feature node to get ambience occlusion,
but I just want to know how to get neighbours point normal.
Can someone tell me how to fix it?
And sorry for my english.
int pt_neighbors[] = neighbours(0, @ptnum);
int num_neighbors = len(pt_neighbors);
vector myNormal = point(0, "N", @ptnum);
for (int i = 0; i < num_neighbors; ++i) {
    int neighbor = pt_neighbors[i];
    v@neighborNormal = point(0, "N", neighbor);//it's {0,0,0}
    f@dot =dot(myNormal, @neighborNormal);
Edited by Cuanyo - Aug. 6, 2023 01:56:47
Ok it's a stupid mistake, the default pighead test geometry is no normal data...
However, it's not my expect result, not like ambience occlusion.
Try to use FeELib-for-Houdini it has endless otls collection and examples like eigenvector neighbors that you can calculate from any direction to make desired effect.
Conservation of Momentum
you can also use Mask By Feature SOP to get Ambient Occlusion based mask attribute
and if you are interested dive inside to look at the code
FX Supervisor
Method Studios, NY
tamte
Thanks for the advice!
I didn't know that node is a subnet, I've dive to look at the code, it's super difficult to me.
hope some day I can understand it.
Thanks again!
cncverkstad
Thanks for the information!
You can also use the primuv function to sample normals anywhere on the surface:
https://www.sidefx.com/docs/houdini/vex/functions/primuv.html [www.sidefx.com]
animatrix_
I'll try to find out how to use this function.
I think you just don't have a normal on the points.
I have run your code and it works. Just put the "Normal" node in front of the wrangle and specify the "points".
