hi all,
i canat seem to get the mkdir command to work in the pre render script of a rop geometry node.. i guess its just a syntax thing… i have..
mkdir $HIP/cache
with the intention of making a directory called cache in the hip folder.
ive tried a few variations but so far no directory is created.. is it the fact that mkdir is a shell command and $HIP is a houdini variable?
ta,
Mark
mkdir pre render script on rop geometry in XP
5490 6 2- MWainwright
- 119 posts
- Joe
- 483 posts
- MWainwright
- 119 posts
- tstex
- 454 posts
- Ondrej
- 1072 posts
- MWainwright
- 119 posts
- edward
- 7722 posts
The reason why “unix mkdir $HIP/cache” doesn't work (eg. from the textport) is because on Windows, the csh.exe (from $HB) is spawned to execute the command. csh.exe is basically a native Windows port of the csh shell from Unix. So you need a mkdir.exe program in order to make a directory. To get one (and other Unix utilities on Windows), you need to download and install cygwin. And then make sure that the ccygwin/bin is available in the PATH environment variable prior to starting Houdini.
Of course, Ondrej gives a nice workaround because umkdir is a hscript command built into Houdini.
