I have tried all the modes except “Custom” and the only one that hangs the system is “Mosaic”. If I go into RizomUV and set the conditions that same as in the RizomUV_Unwrap node then complete the auto select and unwrap processes then save the file. The houdini unwrap node completes the action and you get the UVs unwrapped.
SideFX Labs - RizomUV Bridge
22300 43 7- stevenshook
- 15 posts
- lkruel
- 240 posts
- stevenshook
- 15 posts
- JabbaTheNut
- 48 posts
- Christian_V
- 13 posts
I just tried the rizomuv processor with the preset “Straigthen Set Edges Vertical” and an edge group on the rubber toy.
Also I tried copying manually from Rizom´s Script Log with “Enable Custom Lua” in the Processor Node enabled and “Delete Original UVs” disabled, Group Type set to Edge and Select Groups filled in properly.
Both didn´t seem to work on 17.5, did I do something wrong?
All the best
Christian
All the best
Christian
- lkruel
- 240 posts
- Christian_V
- 13 posts
- pgoodwin88
- silver0694
- Steven Quinones-Colon2
- 22 posts
- 22 posts
- Yuri Serizawa
- 12 posts
- cyclopean_moondust
- 3 posts
- lkruel
- 240 posts
- Qazi-Talal
- johnsmith101
I did the same thing and no fbx file was written. Most likely a bug in the system.
Regards, mobdro [get-mobdro.com]
tubemate [get-tubemate.in]
Edited by johnsmith101 - June 4, 2020 04:42:52
- jomaro
- 85 posts
- Siavash Tehrani
- 710 posts
I'm having the same issue as jomaro with rizom 2020.1. Whenever the RizomUV Unwrap node cooks it opens the actual RizomUV GUI application, does its thing, then closes. I haven't used any versions prior to 2020.1 but looking at this video it seems like that shouldn't be the behavior: https://www.youtube.com/watch?v=wuYC1mwNua8 [www.youtube.com]
- oliver7
- 282 posts
DaJuice
Thats correct behaviour... it processes and then feeds back into houdini..
Oliver Hotz
Origami Digital
Author of ODTools for Houdini: https://origamidigital.com/cart/index.php?route=product/product&path=59_63&product_id=66 [origamidigital.com]
Origami Digital
- Siavash Tehrani
- 710 posts
Hi Oliver, here's what I'm getting if you take a look at the attached mp4. The RizomUV GUI application pops up, steals focus, and then closes. Compare that to the previous YouTube link I posted or the video on this sidefx page, where the application just runs in the background (presumably via command line?): https://www.sidefx.com/tutorials/sidefx-labs-rizomuv-bridge/ [www.sidefx.com]
