Hey all,
I was just curious if there were any Linux users that have transitioned to H19 with little to no problems? I'm using the latest Fedora and while I love it I'd rather be able to run H19 with less problems. I've been through a few rounds of support and have it mostly working with the malloc-debug library but I get random crashes on launch (usually 3 at a time) and just in general it feels shaky. Running 19.0.524 daily and I have been watching the changelog religiously to see if there are any fixes pertaining to this.
I'm not trying to shame the devs or anything - Linux is so diverse and its super difficult to make something work with so many distros. It's really been amazing that it worked so well up until this point. Just gathering data to figure out if there are more stable fish in the sea.
Do older kernels work better? Maybe switch back to Rhel or rhel clone like alma? Seems like Ubuntu has some trouble too? Or does the opposite route work better, going full Arch?
What are you all running and has it been stable?
Linux distro with no problems running H19
7803 25 5- Anthony Morrelle
- 39 posts
- Neil78
- 273 posts
- Anthony Morrelle
- 39 posts
- Neil78
- 273 posts
- Anthony Morrelle
- 39 posts
- ajz3d
- 480 posts
Debian Testing, currently with kernel 5.15 and NVIDIA 470.103.01 proprietary driver. So far, no major problems after upgrading to H19 (knocks on wood). Kernel version 5.16 was rolled out today, but I don't expect it to affect Houdini in any negative way.
I've been using Debian Testing with Houdini for many years, and throughout the time, I have not experienced any serious issues. Apart from an occasional crash of Houdini when I attempt to do something ridiculously silly with nodes.
- Anthony Morrelle
- 39 posts
- ajz3d
- 480 posts
No, but now I noticed that Debian Testing still uses glibc 2.33-5:
https://tracker.debian.org/pkg/glibc [tracker.debian.org]
And from what I see, problems start with glibc 2.34, which is currently in experimental repository.
https://www.sidefx.com/forum/topic/81386/#post-350753 [www.sidefx.com]
So, I guess that in several months from today, I will be starting Houdini with libc_malloc_debug...
Edited by ajz3d - Feb. 16, 2022 14:24:22
- filipw
- 135 posts
- Anthony Morrelle
- 39 posts
ajz3dHa, I hope not.
That makes sense. I'm running glibc 2.34. So if I target a distro running 2.33 I should be ok - not sure why I didn't think of that.
I'm hoping the glibc stuff clicks into place in the next few versions.
Anthony Morrelle
Hired Gun
Hired Gun
- ajz3d
- 480 posts
If you were to target Debian Stable, which is still on glibc 2.31-13, you would have about 2 years of boring stability, as none of the packages would get updated to their newer versions until stable becomes oldstable and next-stable (testing) becomes stable. The only updates you would get, are security patches.
Some newer package versions (like NVIDIA proprietary driver for instance /not sure if those backported include newer CUDA and Optix versions/) can be pulled from backports repository:
https://backports.debian.org/ [backports.debian.org]
https://backports.debian.org/changes/bullseye-backports.html [backports.debian.org]
Anthony MorrelleYes, I hope so too.
- Anthony Morrelle
- 39 posts
ajz3dI used to run CentOS and got so bored with it... I might have to revisit my old friend though. (I'm a rhel guy through and through - debian based systems don't like me, at least as a workstation os). Too bad CentOS as I knew it doesn't exist anymore. I guess I have a few distros to test out
@filipw - I used to hate Gnome because of the huge titlebars, then I got a higher dpi monitor and everything is the right size, ha. Adwaita has gotten a bit nicer lately too.
Anthony Morrelle
Hired Gun
Hired Gun
- ajz3d
- 480 posts
Anthony MorrelleIf that's the case, have you tried Rocky Linux? It's basically the successor of CentOS started by Gregory Kurtzer (the founder of CentOS), and is said to be binary compatible with RHEL. Not sure what glibc version they have though. I think Rocky uses RHEL's repositories, so the version is probably the same as RHEL's.
I used to run CentOS (...) I'm a rhel guy through and through (...) Too bad CentOS as I knew it doesn't exist anymore. I guess I have a few distros to test out
- Anthony Morrelle
- 39 posts
ajz3dI do run Alma linux, which is another rhel clone that also takes the place of CentOS, for some servers and am ok with it. That may be my next stop... Maybe with some XFCE mixed in to make me really nostalgic. Or I've been meaning to use Rhel proper for some time now and see if I'm missing anything.
Edited by Anthony Morrelle - Feb. 16, 2022 16:46:14
Anthony Morrelle
Hired Gun
Hired Gun
- nicholasralabate
- 114 posts
- alex_budulan
- nickfr
- 27 posts
- NicTanghe
- 202 posts
- srinivas_chilukuri
- 3 posts
- protozoan
- 1647 posts
