When I try to open one of the pdf help files from within houdini I get an “acrobat reader not installed” msg. How can i associate these with one of the existing pdf viewers on Linux
tallkien
Help with Help
6075 8 1- tallkien
- 225 posts
- goldfarb
- 3455 posts
- tallkien
- 225 posts
- goldfarb
- 3455 posts
- Undertaker
- 113 posts
- JColdrick
- 4140 posts
Can someone please tell me what this means and how to fix it
Warning: charset “UTF-8” not supported, using “ISO8859-1”.
I assume you're running RH8 or 9?
As root, edit the acroread script(it's actually just a script, not an executable) and add:
LANG=en_US
export LANG
near the beginning of it. Don't use xpdf(bleh )
One of the joys of using RH greater than v7… :twisted:
J.C.
John Coldrick
- soundview00
- 7 posts
- tallkien
- 225 posts
- JColdrick
- 4140 posts
Usually your desktop handles all of this under file associations. For instance, in KDE 3(which I'm running) I go under:
Preferences/File Browsing/File Associations
and look under “text” and then “pdf” and there's good ol' acroread. You could change that to whatever you want. I'm fairly certain Houdini will respect that since I've never notified Houdini over this issue and acroread isn't the default pdf reader - I had to set that up in KDE.
Gnome sets things up in a similar fashion.
I'm unsure(and doubtful) that there's a Houdini-specific setting for this. Possibly it would be mozilla-associated(since it's a porta-mozilla engine they're using). The desktop-wide setting is usually fine for most…
J.C.
J.C.
John Coldrick
