modeling
10710 15 2- ramin22
- 70 posts
- keyframe
- 1529 posts
- ramin22
- 70 posts
- keyframe
- 1529 posts
- jesta
- 311 posts
Houdini's procedural paradigm means that you model in a different way to other packages. Sometimes this requires a little more thought, other times not.
It perhaps doesn't have some of the tools that exist in other packages, but if you know what you are doing I find you can work very quickly.
I do all my modeling in Houdini and have no problem with it.
- Siavash Tehrani
- 710 posts
There's nothing stopping you from making amazing models in Houdini. No doubt there is room for improvement… for example the lack of automatic local orientation of handles, or the lack of edge loop sliding. BUT… even for non-procedural stuff, having the SOP network is so nice that I don't see myself using anything else.
I think what keyframe said was the best advice, you should try it for yourself and decide if you like the workflow.
- heydabop
- 203 posts
- ragupasta
- 349 posts
- stu
- 246 posts
jesta
Agreed.
- ramin22
- 70 posts
- anon_user_40689665
- 648 posts
ramin22
is houdini weaker than other 3d packages in modeling?
There are some weaknesses with particular tools, (as with any other app) and some problems with the core of the modeler when it comes to proceduralism. Despite this you still get a useful set of versatile tools to cover most scenarios - especially where models need to be changed (remodelled, animated or mapped) in reaction to other parts of your scene, as opposed to being a static ‘locked-down’ prop.
As for speed its a matter of practice.
- ramin22
- 70 posts
- stevenong
- 1631 posts
VEX only modifies point data so you're limited to “creating” certain type of modeling tools/functions.
In addition, VEX doesn't work with primitives and it doesn't have the ability to create geometry.
That said, VEX is really good at what it does. For example, replacing certain point operations with VEX speed them up many times.
Cheers!
steven
Cheers!
steven
- ramin22
- 70 posts
- jason_iversen
- 12461 posts
The PythonSOP is probably the best bet for creating general tools, or building SOP OTLs - which can probably get you pretty far.
Unfortunately picking/selection tools and some other useful handle/alignment/snapping tools are things that can't be written by anyone except SESI.
- chrism
- 2493 posts
ramin22
isn't anyway to create maya tools in houdini? i mean without too much difficulty :?:
If there are specific modeling tools that you would like to see, please log an RFE (a feature request) using the handy instructions in this post:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=15702 [sidefx.com]
Chris McSpurren
