As far as I remember, in H14 it used to be that when you right-click on an HDA and select “save node type”, the HDA would save all changes and turn blue.
Now in H15 I am creating HDAs (with the .hdalc extension) and the “save node type” option seems to do nothing at all.
Is this intentional? Is there an option to get the old behavior?
H15 - saving HDAs does not seem to work properly [solved]
4820 11 3- DASD
- 453 posts
- tamte
- 8597 posts
Save Node Type just saves the changes to hda definition, but keeps the asset unlocked (red)
if you want to lock the asset and sync with definition saved to disk you need to do Match Current Definition afterwards
or you can use Asset Menu where those options are Save Asset and Lock Asset respectively
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- DASD
- 453 posts
- awong
- 818 posts
I assume you're looking at another asset, and the new changes are not showing up there? It's possible that your other asset nodes are unlocked. When an asset node is unlocked, the node will have its own changes, and won't update from the HDA file. If that's the case, you should be able to lock it back by right clicking the asset, and select “Match Current Definition”.
Andrew / アンドリュー
- goldfarb
- 3455 posts
- DASD
- 453 posts
I feel really stupid now, but it's still not working. So here's what I tried to do:
1. Create digital asset.
2. Delete it and re-create it from TAB menu (to try and work with it, like I would in a different file)
3. RMB -> Allow editing of contents.
4. Edit stuff inside the HDA
5. RMB -> Save node Type
6. Create the Digital Asset from Tab menu -> It does not have any of the changes from step 4.
Alternative:
5b. RMB -> Type properties , click apply and accept
6. Create the Digital Asset from Tab menu -> New asset has changes from step 5b
Note: When I do step 3, it always becomes “Not synchronized with definition”. But how else can I change the HDA?
So what am I missing?
Alternative:
- MikePaixao
- 36 posts
- DASD
- 453 posts
- MikePaixao
- 36 posts
- DASD
- 453 posts
- awong
- 818 posts
- DASD
- 453 posts
