Hi!
I've created a simple polyline with 3 points and I'm trying to bevel the mid point. The polybevel doesn't work.
Any advice?
-Olivier
Polybevel on polyline?
2137 7 0- olivierth
- 1010 posts
- olivierth
- 1010 posts
- goldfarb
- 3455 posts
- olivierth
- 1010 posts
- olivierth
- 1010 posts
- Nicolas Longchamps
- 37 posts
Ran into this the other day. Polybevel seems sensitive to point/vertex ordering.
Your vertex order is different from your point order. Adding a sort node with sorting set to “by vertex order” will fix the issue. You can also fix the vertex order by changing how you wired them together in your “polyline_90_turn” wrangle. There you call addpoint in top-mid-bottom order, but then call addvertex in bottom-mid-top order.
- anon_user_40689665
- 648 posts
- olivierth
- 1010 posts
