Booleans shatter problem
2487 6 1- Loic_Mattern
- 10 posts
Hello everyone !
I'm having some issues trying to “booleans-shatter” an unpacked terrain with several grids. ( input A : solid, input B : surface, Detriangulate : No-polygons )
The two first booleans work well but the third one gives me weird results and some warning about “nonmanifold edges in solid A”.
After some forum research I tried polydoctor, polyreduce, fuse, divide, clean, but nothing seems to work ( maybe I'm not doing it well, this is very likely… )
Does anyone of you already had this problem ?
Thank you in advance
Network View
Geo to shatter
Template of the cutting geo
Result so far
Infos :
Ubuntu 18.04.2 LTS
Houdini Apprentice Non Commercial 17.5.173
GeForce GTX 1060 Nvidia Driver 390
Network View
Geo to shatter
Result so far
Infos :
Ubuntu 18.04.2 LTS
Edited by Loic_Mattern - April 25, 2019 04:18:17
- mrCatfish
- 731 posts
- Midasssilver
- 310 posts
- BabaJ
- 2040 posts
You probably have to make sure the normals are set ‘right’ after each loop operation before your objects get input into the boolean sop.
I see you have an attribute randomize (what attributes are you randomize? ) and also an attribute vop ( what are you doing in that vop?)…maybe in one of those two is causing a flip in normals which throws off the boolean sop operation.
Perhaps post hip and someone can help you.
- Loic_Mattern
- 10 posts
Thank you for you answer BabaJ
Indeed, I randomize the normal of each point so that each grid isn't oriented the same way.
For the attribute vop I simply use a turbulent noise that I add to the Position of each point, but on the screenshot above it was disabled.
So, I should add an normal after unpacking my geo and just after my copy to point ?
BabaJ
BabaJ
- Loic_Mattern
- 10 posts
- Loic_Mattern
- 10 posts
