Will H18.5\H19 have a normal OpenSubdiv smoothing? It is a killer feature for modeling
Modo like subdivision
2651 7 2- Alexey Vanzhula
- 538 posts
- Island
- 340 posts
- jsmack
- 7772 posts
- tamte
- 8556 posts
- Island
- 340 posts
- PaQ WaK
- 89 posts
Old request… [www.sidefx.com]
Especially the fact you can interact/edit the smooth cage display, it sometimes makes selection way easier.
Edited by PaQ WaK - May 20, 2020 12:50:43
Gameloft
- anon_user_89151269
- 1755 posts
tamteA display but a functionality related feature too, if I understand correctly Alexey's issue.
I believe they are referring to smooth cage display rather than the actual open subdiv implementation
In XSI, I one can edit Sub-Ds with the “cage” visibile or hidden. Again, not sure if this is actually what's being discussed.
Edited by anon_user_89151269 - May 21, 2020 00:08:02
- PaQ WaK
- 89 posts
pickled
Not familiar with XSI, but why is the transform handler position so far from the surface ? I really like Modo way here, because you can tweak the point exactly where the “projected” smooth cage is, not 5 meter away where the cage is supposed to be.
Same thing when you want insert/slide edges, you work on the sub-d surface, not on the hidden cage.
Edited by PaQ WaK - May 20, 2020 19:25:31
Gameloft
