Editing multiple parameters at once...
18266 19 4- peteski
- 517 posts
Hi there,
I have ran into this problem a bit, just wondering, if I have a bunch of null objects (for example), is there a way to edit the size of the whole bunch at once rather than having to dig into each node individually?
Currently I'd just go into each node and select the control node and adjust the scale.
Thanks,
Pete
Thanks,
Pete
- Enivob
- 2536 posts
Select the first one to bring up the properties panel.
Then select all of them and simply make your adjustment in the properties panel. This should change them all.
I just tried adjusting the Icon Scale of the NULL on the Misc tab and it worked. My guess is only nodes with like parameters will be affected by this multi-edit.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- peteski
- 517 posts
Hmm, that wasn't working for me, I may be misunderstanding you though.
I dive into the null node then it's control node to select the size (and other props) open up properties, but then when I head back out to select the other nodes, the property window changes to thier root properties, such as overall transform.
- Andy_23
- 918 posts
- Enivob
- 2536 posts
- cval
- 161 posts
As a supplement of information, here is a thread that had a similar question :
https://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=39308 [sidefx.com]
The best answer was to use the Parameter Spreadsheet as mentioned above
- peteski
- 517 posts
- NNois
- 174 posts
- toonafish
- 409 posts
Sorry to revive this topic.
I'm having similar issues and I've been trying to figure this several times, mostly getting frustrated and ending up editing dozens of objects one by one because I was not able to find a solution.
As an example, I want to edit the size of the Nulls in an imported FBX, but I can't size the top level because that will screw up the rig. I need to go inside the null and set the scale in the SOP/control panel.
I can select and edit multiple objects or Nulls in the Network List View or Parameter Spreadsheet, but there seems to be no way to select and edit multiple SOPs one level deeper.
Has anyone solved this riddle yet ?
I attached a screenshot that might help explaining the issue.
R.
R.
Edited by toonafish - July 1, 2020 06:50:12
- peteski
- 517 posts
Hey maybe check out this toolbar script I posed here. You could use it to select any ‘control’ node (or any other node) and edit them at once
I think it might help.
https://www.sidefx.com/forum/topic/31283/?page=2#post-311707 [www.sidefx.com]
I use it all the time.
P.
P.
- toonafish
- 409 posts
- peteski
- 517 posts
Okay here's how do it!
Right click in an empty part of a shelf and choose ‘New Tool’
Then go to the script section and paste the script in (it's at the bottom of this post).
Press ‘Accept’ on that and you should have a new toolbar button!
Now, select a bunch of nodes and press that button and you should get a dropdown of all the nodes within your selection
Choose one type and in the shared parameters should appear in your ‘Parameters’ Pane, ready for multi editing fun times
#Get all nodes under the current selection ChildSOPs = [] for node in hou.selectedNodes(): for child in node.allSubChildren(): ChildSOPs.append(child) #Make a list of unique types seen = set() UniqueSOPs = [] UniqueSOPsSorted = [] for SOP in ChildSOPs: if SOP.type().name() not in seen: UniqueSOPs.append(str(SOP.type().name())) seen.add(SOP.type().name()) #Added this to allow Object Level nodes to be selected SelectedNodes = [] for node in hou.selectedNodes(): SelectedNodes.append(node) if node.type().name() not in seen: UniqueSOPs.append(str(node.type().name())) seen.add(node.type().name()) #Clear the selection hou.node('/obj').setSelected(False, clear_all_selected=True) #Choose the node type you want to edit UniqueSOPsSorted = sorted(UniqueSOPs,key=str.lower) input = hou.ui.selectFromList(UniqueSOPsSorted, message="Select Node Type!") if (len(input) == 0): print "Cancelled" else: #Multi Select the nodes! for SOP in ChildSOPs: if (UniqueSOPsSorted[input[0]] == SOP.type().name()): SOP.setSelected(True,False) for OBJ in SelectedNodes: if (UniqueSOPsSorted[input[0]] == OBJ.type().name()): OBJ.setSelected(True,False)
Edited by peteski - July 4, 2020 00:58:51
- toonafish
- 409 posts
Thanks a lot for the script and explanation Peteski.
I installed the script and it seems to work, but I don't quite get it.
When I use it with multiple objects selected, it's working basically the same as when I select all my objects in the Network/list view and edit them all at the same time. Or am I misunderstanding what the script is supposed to do ?
What I would like to do is to edit the properties that only seem accessible when you go inside a SOP node. So like in my example before, I'd like to edit the “Control > uniform scale” when you go inside the Null SOP node, and not the “Uniform Scale” that is accessible at the root of the SOP node.
I was hoping our script would also access the controls inside multiple SOP nodes, even if you selected the roots.
But it doesn't seem possible to select multiple of those controls at the same time. The closest thing would be to select them one by one in the Spreadsheet Editor. But that's almost as tedious as editing them one by one the Network editor.
But should it also be possible to edit multiple of those properties simultaneously with your script ?
R.
R.
- peteski
- 517 posts
Yeah that's the whole point of it. I did notice however that it was behaving a little unpredictably with Nulls.
I think it has to do with the parameters of the control nodes referencing the top level parameters of the null node. If I delete the reference it seems to multi edit fine.
But yeah, this has definitely saved me whenever I have to multi edit a bunch of nodes. Travelling into them one by one drives you nuts! Here's a little test, if I select this bunch of nodes and run it, then choose ‘Control’.
You can see in the parameter pane there are a bunch of nodes selected.
Oh, I realised I should have cleared the selection, I added a line to the script in the last post.
See how ya go!
See how ya go!
Edited by peteski - July 4, 2020 01:08:44
- NNois
- 174 posts
- toonafish
- 409 posts
peteski
See how ya go!
Ha, brilliant. After deleting the connection it works like a charm on Nulls as well.
This will save so much time and frustration. Thanks !
R.
- peteski
- 517 posts
- aekorps
- 21 posts
- peteski
- 517 posts
- FFD
- 80 posts
