Move a curve's points parametrically, how?
6747 19 0- Masoud
- 407 posts
- BabaJ
- 2038 posts
What is it you mean/want to do?
In your pic your showing a control handle for a nurbs curve. There are no points on this curve because the curve is calculated, so you can't ‘transform’ any of the ‘points’.
Is it these control handles you want to transform? meaning you want to access and modify the Coordinates parameter directly?
For this, you can maybe do some python work:
https://www.sidefx.com/forum/topic/15022/?page=1#post-71063 [www.sidefx.com]
If it's ‘points’ on the curve though, other than finding out the equation used for making the nurbs curve and working out an equation expression yourself for the x value of your y ;
You could simply use the y value as part of the orig argument of the vex intersect function, and move your point to that location.
http://www.sidefx.com/docs/houdini/vex/functions/intersect.html [www.sidefx.com]
- Masoud
- 407 posts
- BabaJ
- 2038 posts
I guess what you mean is how to find the specific point(handle) in the list of the coordinate parameter quickly and enter it's value there instead of using the mouse? Have a drop down dialogue box for the point(handle) selected in the viewport to quickly enter values?
In such a case I don't know how to do that if it's possible. Thought there was some mention in the H17 presentation about an additon to hom for handles…maybe if it's not possible now, some tool like that could be built with H17.
- goldfarb
- 3455 posts
- BabaJ
- 2038 posts
“is there a reason you can't just append a Transform SOP and specify the point there?”
I don't know if that's what he wants…but some people would probably prefer not having to do that.
Some might want to ‘non-proceduraly’ modify their initial points on the curve with specific values.
Although selecting a curves control point and moving it will show the changes dynamically in the coordinates parameter box, if you have many of them it won't show(the list would be too long); Meaning you can't quickly spot which one in the list it is and just manually enter the value there. (If you know the value you want, and doing it by mouse is to slow to get the specific value, i.e. sensitive mouse).
Having a single drop down box in the viewport on the selected point(handle) to enter values can speed things up; Say if your doing about 10 changes on different points - that would be going through the process of laying down 10 transform sops( each with its' own specified point number).
I'm guessing something like this could be done with the HDK if not python?
Edited by BabaJ - Oct. 9, 2018 13:04:56
- Masoud
- 407 posts
- BabaJ
- 2038 posts
- Olaf Finkbeiner
- 323 posts
- Masoud
- 407 posts
- BabaJ
- 2038 posts
- Masoud
- 407 posts
- BabaJ
- 2038 posts
Yes they do, just not depicted the same way.
In Houdini a line just isn't drawn from the CV to it's control point; but the CV is the Bezier Handle.
Also in Houdini there isn't a visual distinction made for you to see the difference. But you can see it as you move them around.
Just set the curve to Bezier and CV and move the points around - you will see.
Edited by BabaJ - Oct. 11, 2018 04:35:39
- mestela
- 1737 posts
- Island
- 340 posts
I would handle this by starting with add SOPs for each point on the curve, add a merge node that includes all the add nodes, and then specify how these add nodes should be interpreted (b spline, bezier, linear, etc). It is easy to animate a curve that way. I’m away from a computer for a few days but will edit this to give an example file when I get back on Tuesday.
Edited by Island - Oct. 11, 2018 18:04:59
- Masoud
- 407 posts
BabaJ
Ok, thanks you BabaJ.
Edited by Masoud - Oct. 13, 2018 02:44:20
Masoud Saadatmand (MSDVFX)
- Masoud
- 407 posts
mestela
or fake it:
https://www.sidefx.com/forum/topic/40929/#post-185858 [www.sidefx.com]
Thank you Mestela; very helpful.
- Island
- 340 posts
- Olaf Finkbeiner
- 323 posts
https://www.sidefx.com/forum/topic/58427/?page=1#post-261910 [www.sidefx.com]
Thomas Bishop made a bezier handle tool for H17
- Masoud
- 407 posts
Olaf Finkbeiner
Thanks.
