I don't think that was always the case, but since a recent update every time I go between SOP levels the active viewport changes to a “No cam”, rather than maintaining the previously selected render camera.
Is there a new setting to prevent this from happening? I find my self re-selecting the render camera in the viewport all the time as I navigate my network.
viewport keeps changing the camera
8545 14 6- ch3
- 8 posts
- anon_user_89151269
- 1755 posts
- 7803 posts
- ch3
- 8 posts
McNistor
Do you have lock camera toggle off? Although just going in and out of SOPs shouldn't deselect your cam even if the lock toggle is off.
I don't have this problem on my end.Image Not Found
Locking the camera prevents this from happening, but that's not a good solution as I may accidentally change the render camera position. I noticed when setting the triple option above the camera selection to view the rest of the scene, also prevents this issue.
I am in houdini Indie 17.0.459
Which version are using?
I will report it as a bug
thanks
- 1755 posts
ch3
It's probably best to make a habit of putting keys on your camera transformations. I made this habit from working in other programs with no camera lock function, which it seems like it's there so that users have one more thing they can forget about.
I'm using 17.5…
Edited by anon_user_89151269 - April 9, 2019 11:15:44
- 7803 posts
ch3
17.0.506 and 17.5.204
The camera doesn't pop off because of changing contexts, its because the visible objects list changes. The same thing happens if the display filter is changed from ‘Hide Other Objects’ to ‘Ghost Other Objects’ or to ‘Show All Objects’, without changing context. If the filter is on ‘Hide Other Objects’ then the camera pops off the viewer when changing context as well.
- Ondrej
- 1072 posts
I think this has always been the case. When you're in Hide Other Objects and at the SOP level, you're actually in the local space of the object instead of world space. This is not purely a visibility setting. In Houdini, we conflate it with which space the viewer is showing. When the viewer changes coordinate systems like this, it also transforms the view so that there is no sudden jump. It is because of this change in view that we have to unset the camera.
It's like this for historical reasons. We realise how weird this is and will be separating the two concepts (eventually).
Edited by Ondrej - April 9, 2019 14:33:56
- mrCatfish
- 731 posts
This is a bug. I just tried Houdini 15 and it didn't do this, not matter if “hide other objects” was on or off. I don't recall it happening in 16 or 16.5, so I don't know when it got introduced but it was fairly recently. It drives me nuts. I will file a bug report, I suggest everyone else bothered by this do the same.
Sean Lewkiw
CG Supervisor
Machine FX - Cinesite MTL
CG Supervisor
- Ondrej
- 1072 posts
- Ondrej
- 1072 posts
- pbowmar
- 7025 posts
- drossxyu
- 31 posts
- pabcou
- 61 posts
drossxyuThis is a different issue. It's related to Redshift and due to recent changes in the HDK. A fix is already available in RS3.0.04. See here [www.redshift3d.com] in the RS forums for more info.
It will randomly flip my perspective upside down and the only way to recover is to press space+g to reset the screen. It's happening constantly and also causing my redshift render view to bug out.
- 1755 posts
A different issue, reproducible like this:
- orbit around your selection until the negative half-space of Y gets above the horizon line; you're basically upside-down and your orbiting control is “inverted” now
- Space + F to frame your selection and fix the inverted control
- going back to normal view (positive Y half-space) and your orbiting control is inverted again, so Space + F to fix it
Not sure if it's a bug, but I'm suspecting that it is, because this doesn't happen when locked in a user created camera, only when in the Houdini's implicit one.
Edited by anon_user_89151269 - July 8, 2019 11:45:52
- eikonoklastes
- 333 posts
