Houdini 19 doesn't load AT ALL on Ubuntu 21.10
45366 118 18- Mirko Jankovic
- 102 posts
- Hampus Hedberg2
- 13 posts
alunablue
Do not try to overwrite your nvidia driver.
You must completely remove everything to do with nvidia:
sudo apt-get remove --purge '^nvidia-.*'
Then reinstall the desktop:
sudo apt-get install ubuntu-desktop
You can then install nvidea-driver-470 (proprietary, tested)
Hope that helps.
Thanks for taking the time, but I'm already running 470, never ran a newer version.
It definitely happened between 21.04 and 21.10 as it worked flawlessly before.
Everything except Houdini also works as intended.
Also, since the same thing happens in 18.5 I'm guessing it's some library in the system that has changed functionality somehow.
Edited by Hampus Hedberg2 - Dec. 31, 2021 06:34:02
- ajz3d
- 477 posts
For what it's worth, I haven't experienced any of those problems on current Debian Testing (Bookworm).
libxcb:
I don't use any extraordinary envvars in
Version 19.0 does come with its own share of brand new annoying problems, when compared to 18.5 (I think something in Qt has changed for the worse), but fortunately for me, none of them are what you guys have described here. Nothing that prevents Houdini from running on Debian Bookworm.
I tested Karma XPU, and so far it didn't segfault on me.
While my post might not be very helpful, I think it at least proves that
kernel
: 5.15.0-2-amd64, #1 SMP Debian 5.15.5-2 (2021-12-18)-
nvidia-driver
: 470.86-1-
libopengl0
: 1.3.4-2+b1-
freeglut3
: 2.8.1-6-
freeglut3-dev
: not installedlibxcb:
libpthread-stubs0-dev/testing,now 0.4-1 amd64 [installed,automatic]
libxcb-composite0/testing,now 1.14-3 amd64 [installed,automatic]
libxcb-cursor0/testing,now 0.1.1-4 amd64 [installed,automatic]
libxcb-damage0/testing,now 1.14-3 amd64 [installed,automatic]
libxcb-dri2-0/testing,now 1.14-3 amd64 [installed,automatic]
libxcb-dri3-0/testing,now 1.14-3 amd64 [installed,automatic]
libxcb-ewmh2/testing,now 0.4.1-1.1 amd64 [installed,automatic]
libxcb-glx0/testing,now 1.14-3 amd64 [installed,automatic]
libxcb-icccm4/testing,now 0.4.1-1.1 amd64 [installed,automatic]
libxcb-image0/testing,now 0.4.0-1+b3 amd64 [installed,automatic]
libxcb-keysyms1/testing,now 0.4.0-1+b2 amd64 [installed,automatic]
libxcb-present0/testing,now 1.14-3 amd64 [installed,automatic]
libxcb-randr0/testing,now 1.14-3 amd64 [installed,automatic]
libxcb-render-util0/testing,now 0.3.9-1+b1 amd64 [installed,automatic]
libxcb-render0/testing,now 1.14-3 amd64 [installed,automatic]
libxcb-render0-dev/testing,now 1.14-3 amd64 [installed,automatic]
libxcb-res0/testing,now 1.14-3 amd64 [installed,automatic]
libxcb-shape0/testing,now 1.14-3 amd64 [installed,automatic]
libxcb-shm0/testing,now 1.14-3 amd64 [installed,automatic]
libxcb-shm0-dev/testing,now 1.14-3 amd64 [installed,automatic]
libxcb-sync1/testing,now 1.14-3 amd64 [installed,automatic]
libxcb-util1/testing,now 0.4.0-1+b1 amd64 [installed,automatic]
libxcb-xfixes0/testing,now 1.14-3 amd64 [installed,automatic]
libxcb-xinerama0/testing,now 1.14-3 amd64 [installed,automatic]
libxcb-xinput0/testing,now 1.14-3 amd64 [installed,automatic]
libxcb-xkb1/testing,now 1.14-3 amd64 [installed,automatic]
libxcb-xv0/testing,now 1.14-3 amd64 [installed,automatic]
libxcb1/testing,now 1.14-3 amd64 [installed,automatic]
libxcb1-dev/testing,now 1.14-3 amd64 [installed,automatic]
houdini.env
nor in Houdini launcher. Just some variables related to 3rd party stuff. I'm not LD_PRELOAD
-ing any libraries.Version 19.0 does come with its own share of brand new annoying problems, when compared to 18.5 (I think something in Qt has changed for the worse), but fortunately for me, none of them are what you guys have described here. Nothing that prevents Houdini from running on Debian Bookworm.
freeglut3-dev
package is not mandatory for launching Houdini 19. If you have any questions about specific packages and their versions that I have installed, don't hesitate to ask.
Edited by ajz3d - Dec. 31, 2021 13:50:14
- mzigaib
- 949 posts
- mzigaib
- 949 posts
- Aietes
- 12 posts
- Mirko Jankovic
- 102 posts
- Hampus Hedberg2
- 13 posts
- chrism
- 2494 posts
Remember you can contact support@sidefx.com if you're having problems installing or running Houdini.
The requirements have changed between 18.5 and 19.0, and some of the OS's have changed what they install by default in their more recent versions.
Check our system requirements page: https://sidefx.com/sysreq [sidefx.com]
Chances are you're missing some libraries that Houdini needs.
For example, many of our users have found that one or both of these commands sort things out for them:
sudo apt install libopengl0 freeglut3 freeglut3-dev
sudo apt-get install --reinstall libxcb-xinerama0
At any rate, support can help you if you can't get up and running. Please contact them.
Chris McSpurren
- edward
- 7734 posts
FWIW, I think the best workaround for now on glibc 2.34 distro's (anything ubuntu related 21.10+ or Fedora 35+) is to do the following that permanently disables use of jemalloc. Make sure to NOT set LD_LIBRARY_PATH nor LD_PRELOAD after doing this:
This of course will make Houdini run slow as molasses so the best solution is still to downgrade your distro unfortunately. Or if someone is a super Linux user, figure out a way to preload an older glibc version when running Houdini. For background, glibc maintainers pretty much said that they intended to break backwards compatibility and will never add it back: https://sourceware.org/bugzilla/show_bug.cgi?id=16939 [sourceware.org]
cd $HFS/dsolib cp libjemalloc.so.1 empty_jemalloc/libjemalloc.so.1.orig cp empty_jemalloc/libjemalloc.so.1 .
Edited by edward - Feb. 25, 2022 09:29:45
- tas3d
- 120 posts
Im on Ubuntu 20.04.4 LTS, H19.0.531, AMD Ryzen 9 and Nvidia 2070 GPU.
Getting this crash on houdini startup
I tried few suggested fixes mentioned above:
But still no love.
Running export LD_PRELOAD="/lib/x86_64-linux-gnu/libc_malloc_debug.so.0 doesn't work, it seems like this file does not exist on my system. I have already libc6 installed, perhaps I need something else?
I contaced SESI support, but they have no solution. Any ideas?
Houdini FX Version 19.0.531 [linux-x86_64-gcc9.3] Uptime 1 seconds Fri Mar 4 09:37:44 2022 Caught signal 11 Traceback from 2951 ThreadId=0x7f1b4aa7fe00 AP_Interface::coreDumpChaser(UTsignalHandlerArg) <libHoudiniUI.so> AP_Interface::si_CrashHandler::chaser(UTsignalHandlerArg) <libHoudiniUI.so> signalCallback(UTsignalHandlerArg) <libHoudiniUT.so> UT_Signal::UT_ComboSignalHandler::operator()(int, siginfo_t*, void*) const <libHoudiniUT.so> UT_Signal::processSignal(int, siginfo_t*, void*) <libHoudiniUT.so> __funlockfile <libpthread.so.0>
But still no love.
Edited by tas3d - March 4, 2022 13:43:08
Michal Tas Maciejewski @ www.vfxtricks.com
- edward
- 7734 posts
tas3d
Probably something related to your set up since other people seem to work fine? eg. https://www.sidefx.com/forum/topic/81386/?page=3#post-353732 [www.sidefx.com]
To first see if it's video driver related, run these commands (after sourcing houdini_setup)
$ lsb_release -a $ hgpuinfo
- tas3d
- 120 posts
thanks for helping edward!
notice seg fault at the end of hgpuinfo
hgpuinfo OpenGL Vendor: NVIDIA Corporation OpenGL Renderer: NVIDIA GeForce RTX 2070 SUPER/PCIe/SSE2 OpenGL Version: 4.6.0 NVIDIA 470.103.01 OpenGL Shading Language: 4.60 NVIDIA Detected: NVidia Consumer 8192 MB 470.103.1.0 Supported Extensions not in OpenGL 3.3 (Version): GLX_SGI_swap_control GL_ARB_base_instance (4.2) GL_ARB_bindless_texture GL_ARB_bindless_texture GL_ARB_buffer_storage (4.4) GL_ARB_clear_buffer (4.3) GL_ARB_compatibility GL_ARB_compute_shader (4.3) GL_ARB_copy_texture (4.3) GL_ARB_debug_output GL_ARB_draw_indirect (4.0) GL_ARB_gpu_shader5 (4.0) GL_ARB_gpu_shader_fp64 (4.0) GL_ARB_multi_bind (4.4) GL_ARB_program_interface_query (4.3) GL_ARB_robustness GL_ARB_sample_shading (4.0) GL_ARB_separate_shader_objects (4.1) GL_ARB_shader_atomic_counters (4.2) GL_ARB_shader_image_load_store (4.2) GL_ARB_shader_storage_buffer_object (4.3) GL_ARB_shading_language_packing (4.2) GL_ARB_tessellation_shader (4.0) GL_ARB_texture_buffer_object_rgb32 (4.0) GL_ARB_texture_buffer_range (4.3) GL_ARB_texture_cube_map_array (4.0) GL_ARB_texture_filter_anisotropic (4.6) GL_ARB_transform_feedback3 (4.0) GL_ARB_vertex_attrib_64bit (4.1) GL_EXT_abgr GL_EXT_blend_minmax GL_EXT_direct_state_access GL_KHR_debug (4.3) GL_NVX_gpu_memory_info GL_NV_depth_buffer_float GL_NV_gpu_shader5 Unsupported OpenGL Extensions used by Houdini: EXT_extensions_string GL_ATI_meminfo OpenGL Limits: ELEMENTS_VERTICES 1048576 ELEMENTS_INDICES 1048576 VERTEX_UNITS 32 TESS_CONTROL_TEXTURE_IMAGE_UNITS 32 TESS_EVALUATION_TEXTURE_IMAGE_UNITS 32 GEOMETRY_UNITS 32 FRAGMENT_IMAGE_UNITS 32 COMBINED_UNITS 192 TEXTURE_SIZE 32768 3D_TEXTURE_SIZE 16384 CUBE_MAP_TEXTURE_SIZE 32768 RECTANGLE_TEXTURE_SIZE 32768 TEXTURE_ARRAY_LAYERS 2048 MAX_COLOR_TEXTURE_SAMPLES 32 MAX_DEPTH_TEXTURE_SAMPLES 32 FBO_ATTACHMENTS 8 DRAW_BUFFERS 8 VIEWPORT_DIMS 32768x32768 VERTEX_UNIFORMS 4096 FRAGMENT_UNIFORMS 4096 VERTEX_ATTRIBS 16 VERTEX_OUTPUT_COMPONENTS 128 MAX_CLIP_DISTANCES 8 PATCH_VERTICES 32 TESS_GEN_LEVEL 64 TESS_PATCH_COMPONENTS 120 TESS_CONTROL_OUTPUT_COMPONENTS 128 TESS_CONTROL_TOTAL_OUTPUT_COMPONENTS 4216 TESS_EVALUATION_OUTPUT_COMPONENTS 128 GEOMETRY_UNIFORM_COMPONENTS 2048 GEOMETRY_INPUT_COMPONENTS 128 GEOMETRY_OUTPUT_COMPONENTS 128 GEOMETRY_TOTAL_OUTPUT_COMPONENTS 1024 GEOMETRY_OUTPUT_VERTICES 1024 UNIFORM_BLOCKS 84 UNIFORM_BLOCK_SIZE 65536 UNIFORM_BUFFER_BINDINGS 84 COMBINED_VERT_UNIFORM_BLOCKS 14 COMBINED_VERT_UNIFORM_COMPS 233472 TESS_CONTROL_UNIFORM_BLOCKS 14 TESS_CONTROL_UNIFORM_COMPONENTS 2048 TESS_EVALUATION_UNIFORM_BLOCKS 14 TESS_EVALUATION_UNIFORM_COMPONENTS 2048 COMBINED_GEO_UNIFORM_BLOCKS 14 COMBINED_GEO_UNIFORM_COMPS 231424 COMBINED_FRAG_UNIFORM_BLOCKS 14 COMBINED_FRAG_UNIFORM_COMPS 233472 MAX_FRAGMENT_STORAGE_BLOCKS 16 MAX_STORAGE_BLOCK_BINDINGS 96 TRANSFORM_FEEDBACK_INT_COMPS 128 TRANSFORM_FEEDBACK_SEP_COMPS 4 TRANSFORM_FEEDBACK_SEP_ATTRIBS 4 LINE_WIDTH_RANGE 0.5 - 10 LINE_WIDTH_GRANULARITY 0.125 POINT_SIZE_RANGE 1 - 189.875 POINT_SIZE_GRANULARITY 0.125 Segmentation fault (core dumped)
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 20.04.4 LTS
Release: 20.04
Codename: focal
- tas3d
- 120 posts
I got it, I installed lsb-core package.
H19 starts up!
thanks a million
sudo apt-get install lsb-core
H19 starts up!
thanks a million
Edited by tas3d - March 4, 2022 15:53:55
- edward
- 7734 posts
- tas3d
- 120 posts
haha, im happy it runs
yes, now hgpuinfo finishes.
Seems like it was crashing on querying OpenCl Platform info block.
Edited by tas3d - March 4, 2022 22:13:54
- edward
- 7734 posts
- rasmus.ronnqvist
I managed to get Houdini 19 to load on Fedora 35.
Graphics: Nvidia Proprietary Drivers. 510.47.03
Kernel: 5.16.16-200.fc35.x86_64
WM: awesome (x11)
I had the same issue posted in this thread. The launcher installed like normal but I could not start any Houdini version. I was only met with the Error:
Using the Information posted in this thread I managed to get Houdini 19 running.
This is what i did.
First I installed all the dependencies. I do not know if this is necessary but a previous user recommended this.
Then I sourced the houdini_setup_bash and preloaded libc_malloc_debug.so.0. Ubuntu users apparently have to do something similar but this file is located in /lib64/ on Fedora 35.
Now after doing all this and executing "houdini &" in "/opt/hfs19.0/" Houdini 19 starts like normal.
WM: awesome (x11)
munmap_chunk(): invalid pointer Aborted (core dumped)
This is what i did.
sudo dnf install libxcb libxcb-devel xcb-util xcb-util-devel xcb-util-*-devel libX11-devel libXrender-devel libxkbcommon-devel libxkbcommon-x11-devel libXi-devel libdrm-devel libXcursor-devel libXcomposite-devel
cd /opt/hfs19.0/ source houdini_setup_bash export LD_PRELOAD="/lib64/libc_malloc_debug.so.0" houdini &
Edited by rasmus.ronnqvist - April 7, 2022 13:50:39
- nickfr
- 27 posts
- edward
- 7734 posts
Wayland is not currently supported AFAIK, nor have I heard of anyone using Houdini on Wayland. Fedora 35 is a non-starter because it uses glibc 2.34, wayland or no wayland.
Again, please see https://www.sidefx.com/forum/topic/81386/?page=4#post-357435 [www.sidefx.com] where I think disabling jemalloc is probably a better workaround than preloading the DEBUG glibc allocator. Using Houdini on Fedora 35 with these workarounds will be slower than running Houdini on a distro still running on glibc 2.33 or below.
Edited by edward - April 3, 2022 13:07:22
