Make auto-save on default
21591 14 7-
- mzigaib
- 1067 posts
- Ondrej
- 1082 posts
- galagast
- 277 posts
Hi, thanks for this.
I just wanted to make a note here just in-case I forget the method in the future.
Windows:
Windows:
- Go to your Documents/HoudiniX.X
- Create a “scripts” folder.
- Inside the scripts folder, create a 123.cmd (or also a 456.cmd) file - using notepad will do.
- Add “autosave on” for the files (without quotes).
So far, that is how it worked on my Win10, Houdini Indie 15
- Raphtillie
- 5 posts
- peteski
- 546 posts
- f4xc0rp
- 12 posts
- mandrake0
- 659 posts
It's in the doc's.
456.cmd or 456.py will be executed when the user loads a hip file.
https://www.sidefx.com/docs/houdini/hom/locations.html#startup [www.sidefx.com]
- SWest
- 313 posts
While you're at it, add a line that creates a new folder (maybe today's date) and saves your file there because I don't think auto save will work unless you first do that.
Here's some Py for your shelf
# AUTOSAVE TOGGLE autoSave = hou.getPreference('autoSave') if autoSave == '1': hou.setPreference('autoSave','0') hou.ui.displayMessage('Autosave is now disabled') if autoSave == '0': hou.setPreference('autoSave','1') hou.ui.displayMessage('Autosave is now active')
Edited by SWest - 2023年8月9日 07:00:40
- Jonathan de Blok
- 315 posts
If you place the afterSceneSave handler, linked below, in the same scripts folder it will do some housekeeping only keeping a certain number of backups, see source to set the number to keep. (make sure to keep the exact filename, houdini uses that to identify it's function)
https://www.dropbox.com/scl/fi/pv3v2rm1gnhovy6cj23hv/afterscenesave.py?rlkey=608r3wn14kx89zvs746najcet&dl=0 [www.dropbox.com]
More code, less clicks.
- BenjaminMarkus
- 33 posts
Jonathan de Blok
This script sounds useful, but I'm getting the following error, and don't know enough Python to troubleshoot:
" File \"C:/Users/User/Documents/houdini20.0/scripts/afterscenesave.py\", line 12
print \"WARNING, saving into a backup folder.. skipped pruning\"
SyntaxError: Missing parentheses in call to 'print'. Did you mean print(\"WARNING, saving into a backup folder.. skipped pruning\")?
I'm not sure if this means it's not pruning. I assume not as all previous backups and autosaves still exist. What do you mean by exact filename? The exact filename of the script?
Any insight would be great.
Thanks,
- peteski
- 546 posts
- BenjaminMarkus
- 33 posts
- BenjaminMarkus
- 33 posts
BenjaminMarkuspeteski
I think now (in python 3) you have to put the print in brackets. So print ("Blah") or something like that. You could probably just remove that line or comment it out too.
Yeah that was the first thing I tried, but I still seemed to error out. I'll try again, also with it commented out.
I guess I forgot to add parenthesis to all the print commands. No more errors, but it still doesn't look like the script is working and pruning the old autosave and/or backups.
- OneBigTree
- 403 posts
- sans_comic
- 9 posts
I am a bit confused about the current situation, post H22. There is a toggle now in Preferences > General > Auto Save. But does this still work on a per-file basis?
I was expecting turning it 'On' would be a global setting, and would be respected for all files thenceforward. But when I open a new file, after I have set the option 'On', the new file still doesn't have 'Auto Save' 'On' and I have to switch it on manually.
Do I still have to use a script to enable this globally for all files, despite there being a seemingly global setting?
