Oh my god, how dare SideFX?
So the Game-Dev team just went and built that tool? And in one of the videos Luiz even says, that he might change the tool defaults from “uv” to blank because “it might be useful for other places”..
Turn Edges into Curve
81808 34 7- anon_user_58123709
- 86 posts
- fabriciochamon
- 67 posts
- Houdini_Zero
- 12 posts
- rmagee
- 1182 posts
Tinkering with the dissolve tool there are a couple things to watch out for. It only works on boundary edges therefore you may need to delete the polygons beside the edge you want to extract - that is if you are trying to get edges or loops “inside” a topology. The second step would then be to select the boundry edges you want(either by hand or with a group) and then press delete (which creates a dissolve sop). On the Dissolve SOP, set Operation to Delete Non-Selected and then set Remove Inline points to OFF - this is especially important if you selected a loop because then ALL the points are inline points and you will see nothing. If you do these steps you should be OK:
- rlvelocity
- 15 posts
robsdesign
Not sure if this helps but I've found some of the tools useful…
https://www.sidefx.com/forum/topic/56685/ [www.sidefx.com]
The “GameDev Edge Group to Curve” sop might be useful for this…
I had also struggled with extracting an edge loop from a model and this worked perfectly. Thanks! It's now called “Labs Edge Group to Curve” since the “Game Dev” naming was dropped in H 18. The node's ability to “enable thickness” made me smile since it saved me having to set up a sweep.
With game dev/labs nodes, I usually close my eyes and hold my breath before seeing if I've crashed my project Most of the time, they work fine.
- PaQ WaK
- 89 posts
- lkruel
- 240 posts
- ctedin
- 69 posts
- Pavini
- 27 posts
- 8551 posts
Paulo Cunha2as the old saying goes:Konstantin MagnusNathan Apffel
Its hard to believe that these are the best solutions in Houdini for extracting a curve from an edge.
Houdini is a toolbox, not a toy.
This is why the Houdini artists lack of creativity.
give artist a Curve From Edges SOP and he will be able to create curve from edges
teach artist how to make Curve From Edges SOP and he will be able to solve all sorts of problems without having to complain about missing tools
I personally think the second requires much more creativity, but regardless there is now a Curve From Edges SOP in Houdini (technically an alias to updated Convert Line SOP)
- lewis_T
- 237 posts
Paulo Cunha2Konstantin MagnusNathan Apffel
Wow. Brilliant insight.
L
- dreamblk
- 16 posts
- dreamblk
- 16 posts
- 8551 posts
dreamblkwhat made you revive this thread?
this all is a joke just make a curve from the edges sop and stop with all the unnecessary steps.
Houdini is falling short when it comes to simple tasks that when multiplied are costing people hours of unnecessary wasted time.
Labs edge to curve is okay but sometimes buggy.
the Curve from Edges SOP has been there for some time so no extra steps are necessary since then, however if you are running into some issues you may want to clarify more
- Soothsayer
- 858 posts
