Does anyone use a 6 core AMD Phenom 3.2ghz machine? I'm trying to do some benchmarks on real Mantra rendering vs our Intel machines and I would very much appreciate if I can send someone an IFD file (or .hip file) to test render. It would be completely self contained so you should be able to load and click render
Peter B
Benchmarks on 6 core Phenom?
37659 41 6- pbowmar
- 7025 posts
- malexander
- 5161 posts
I do not have one, but Tom's Hardware has a fairly decent CPU comparison chart:
http://www.tomshardware.com/charts/desktop-cpu-charts-2010/benchmarks,112.html [tomshardware.com]
Mantra isn't included, but Cinebench and 3D Studio Max renderers are. Might help if all else fails The AMD hexacore 3.2GHz CPU performs about like a i7 960 in both cases.
- Pagefan
- 519 posts
- Solitude
- 373 posts
- symek
- 1390 posts
- pbowmar
- 7025 posts
Cool, thanks guys.
Mark, that's a great benchmark site, the issue is that the CPU I have at work isn't on the list (it's an E5440 quad core, x2 CPUs) and I really like “real world” benchmarks since the numbers don't tell me how it will feel
However, certainly price/performance is with AMD on this one. Shame I can't find a dual-CPU AM3+ mobo and have 12 cores
I'll get that IFD up on the weekend!
Peter B
Peter B
- malexander
- 5161 posts
AMD's dual motherboards are strictly socket F or G34, not AM2/3/+ (I believe). A 12-core Mangy-cours CPU clocks out at 2.4GHz, and isn't suitable for workstation work.
The i7 930 would be the closest to your E5440, though it only has 8MB of cache rather than 12, and is 60Mhz slower. Most benchmarks show that increasing cache size at that level has only a very small effect on performance.
- pbowmar
- 7025 posts
- pbowmar
- 7025 posts
OK here's the IFD file along with the resultant image (or as I call it, “art”)
On my dual core Athlon 4400+ it was 44 minutes. This was Suse 11.2, using “gcc 4.3” build.
On my dual core laptop with T5550 1.83Ghz Core Duo, it was 60 minutes. This was Vista 32bit.
Note that I used 11.0.542 to enable the new option to disable displacement shaders (applied to the ROP). I'm including the .hip file in case people want to take a look.
However, please use this IFD file in 11.0.542 for the benchmark to ensure complete apples to apples, if at all possible. If not possible any info is OK too.
If you're on Linux or OSX, open a shell with Houdini set up and simply do:
mantra < benchmark.ifd
Note that it will write a file called “benchmark.pic” in the same directory.
On Windows, from the Start Menu, go to the Houdini version and open a Command Line Tools DOS window. Type the drive letter of the drive the .ifd file is on, hit enter, then “cd” to the directory with the IFD. Once there, do:
just like on Linux. Same thing, a benchmark.pic will be written to the same directory.
I'd love to hear about anyone's findings! I'll try this at work on 4 and 8 cores of our work machines, plus the OSX machines we just bought. On Thursday or Friday when I'm back at work, at least
Peter B
Peter B
- wolfwood
- 4262 posts
- Alanw
- 320 posts
Howdy,
I gave this a shot on two machines. Both running Houdini 11.0.542. The Linux box uses the gcc 4.4 build.
Mac OSX 10.6 Snow Leopard / 2.8 GHz Core i5 4GB RAM (quad core, doesn't have hyperthreading)
Render Time: 43:37.86u 7.86s 11:44.66r
Memory: 142.71 MB of 10.58 GB arena size
Gentoo Linux 2.6.34-gentoo-r12 gcc 4.4.4 Dual Intel(R) Xeon(R) CPU E5520 @ 2.27GHz 24GB RAM with Hyperthreading on (16 threads)
Render Time: 78:01.39u 25.34s 5:01.32r
Memory: 119.58 MB of 120.52 MB arena size. VM Size: 1.13 GB
- mark
- 2593 posts
Ubuntu 8.04 x86_64:
Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz (HT enabled)
Render Time: 65:36.89u 29.61s 8:26.58r
Memory: 73.80 MB of 74.33 MB arena size. VM Size: 565.63 MB
Ubuntu 8.04 x86_64:
Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz
Render Time: 45:04.50u 15.40s 11:38.54r
Memory: 55.27 MB of 56.71 MB arena size. VM Size: 276.78 MB
Ubuntu 8.04 i686:
Intel(R) Core(TM) i3 CPU 540 @ 3.07GH (HT enabled)
Render Time: 3.62u 69:43.21s 17:49.99r
Memory: 45.16 MB of 46.54 MB arena size. VM Size: 81.13 MB
Maybe we should post this on a wiki somewhere [odforce.net]?
P.S. Those times on the i3 look suspicious – it looks like the user and system times might be swapped.
- splitpoint
- 57 posts
- JColdrick
- 4140 posts
Apologies, but I don't have access to that exact build, but I rendered the same results with both 11.0.527 and 11.0.547: a little over 5.5 minutes.
Render Time: 44:36.43u 17.67s 5:42.73r
I'm running the same software as Peter, SUSE 11.2, the gcc 4.3 build, and the hardware is:
Intel(R) Core(TM) i7 CPU 975 @ 3.33GHz
with hyperthreading turned on.
J.C.
J.C.
John Coldrick
- pbowmar
- 7025 posts
- JColdrick
- 4140 posts
“Eight” cores(quotes courtesy Hyperthreading Inc ). That seems somewhat comparable with your results, yeah? My clock speed is a little faster…
J.C.
P.S. the full blurb on the cpu is “Intel i7 Quad Core Enhanced Performance V2”
P.P.S. Well, no it doesn't seem comparable. You're running two cpus, I'm running one with HT. According to the scuttlebutt I keep reading here, I'm supposed to be penalized more heavily, yes? This is why I've been mystified by all the negative talk about HT.
J.C.
John Coldrick
- jason_iversen
- 12513 posts
mark
I never know which is which, really. I just look for the biggest number
- pbowmar
- 7025 posts
My work benchmarks now include on OSX 10.6 8core 2.4ghz Intel (not sure exactly the CPU)
5:40
which is very fast IMO
Sadly, we had a 12 core (dual 6core) test machine in that has since been returned. My tests at the time showed an almost 50% speed increase over our normal (spec'd above) 8 core machines.
Anybody able to test the 6 core Phenom 3.2ghz? This is all great, but none of these faster ones can I afford
Peter B
5:40
Peter B
- Korhon
- 334 posts
- pbowmar
- 7025 posts
